My TV does not have a coax input. Is there a way to connect an OTA antenna to the TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-16-2013, 08:29 PM - Thread Starter
aapina2000's Avatar
I have a Westinghouse LCD that doesn't have a coax input. Is there a way to connect an OTA HD antenna to the TV? I have a single HDMI input that I've connected a switcher to so I can have multiple devices. Any suggestions are welcome (except buying a new TV).
Thank you,
aapina2000 is offline
post #2 of 5 Old 08-16-2013, 08:39 PM
mirayge's Avatar
That sounds like a monitor more than a TV. What model number, and does the manual say anything about having an ATSC or QAM tuner?
By the way a moderator may move this to the proper forum.
mirayge is offline
post #3 of 5 Old 08-16-2013, 08:40 PM
gregzoll's Avatar
Liked: 33
It does help to know the model number of the unit. As for solving your issue, you would need to purchase a OTA add-on tuner for ATSC & QAM, such as this http://www.channelmaster.com/Digital_TV_and_HDTV_HD_digital_Antenna_Tuner_CM_7001_s/287.htm Channel Master is just one company out there that makes these boxes. They do also offer a DVR model. The Silicon Dust models at http://www.newegg.com/Video-Devices-TV-Tuners/SubCategory/ID-47?Tpk=atsc%20tuner are popular also. It is really how much are you willing to spend, and what extra features are you looking for.
Now of course you could get a refurb desktop or tower unit from say Tigerdirect.com and roll your own HTPC with a add-on ATSC tuner card, which would give you more options than most off the shelf manufactured OEM units out there.
gregzoll is offline
post #4 of 5 Old 08-19-2013, 07:50 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If it si indeed a monitor, then you will also need some sort of speakers.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 5 Old 08-19-2013, 02:15 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply Cable, Digital Cable - Non-HDTV
