Basic cable into a Home Theater setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-26-2013, 01:22 PM - Thread Starter
carmstrong's Avatar
We just more or less "cut the cord" on cable. We now just have super basic cable coming into the house. Still get the local channels in HD so that's all we need.
However, our home theater consists of a surround sound receiver and a projector. How do I go about connecting coax cable into this setup? I could buy a converter, but I need a way to tune and change the channels. I'm hoping there's just some quick and easy box out there that does what we need.
Thanks for any help!
-Chris
carmstrong is offline
post #2 of 5 Old 11-26-2013, 02:31 PM
Ratman's Avatar
Quoted: 1434 Post(s)
Liked: 1146
Assuming the coax from cable is connected to "something" with a digital tuner, it should have a digital audio output to connect to your surround sound receiver.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 5 Old 11-26-2013, 04:42 PM
Liked: 62
You need an external QAM tuner since I don't recall ever seeing a projector with a built in tuner. There are a few on the market, like this one:
http://www.solidsignal.com/pview.asp?p=cm-7001&d=channel-master-cm7001-atsc/qam/ntsc-digital-hd-antenna-tuner-cm-7001&sku=020572070010&utm_campaign=base&utm_medium=organic&utm_source=google_base
Or this:
http://www.newegg.com/Product/Product.aspx?gclid=CNC1w-7dg7sCFQ3hQgodm0kAyQ&Item=N82E16815260027&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Video+Devices+%26+TV+Tuners-_-N82E16815260027&ef_id=UpU-3gAAAaanGtiX:20131127004206:s
Depending on what projector and receiver you have, of course.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #4 of 5 Old 11-27-2013, 05:34 AM
Ratman's Avatar
Liked: 1146
Or this:
http://www.amazon.com/Samsung-GX-SM530CF-Streaming-Player-Built-In/dp/B00EYO241Q
Ratman is offline
post #5 of 5 Old 11-27-2013, 07:30 AM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
The Samsung might be a better choice as there's no telling how long Clear QAM will last in your neighborhood.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Cable, Digital Cable - Non-HDTV
