New to drop amps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-08-2014, 10:04 PM - Thread Starter
foxc33's Avatar
I am in the process of buying a house, an older couple lived there just before us and we noticed in the basement it had a box with cable wires attached to it. I did a little research and found out it is an electoline EDA-FT08100. Unfortunately that is all I know about the product, could anyone help me out and tell me exactly what it is and what capabilities I have with this?
Cliff
foxc33 is offline
post #2 of 3 Old 05-08-2014, 10:44 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
...what capabilities I have with this
Depends on who put it there and why. There are two basic scenarios: either you have low signal from the cable company and they (or someone who knows what they're doing) placed it to compensate for it, or you have OK signal and it's not needed and was put there because somkeone thought it was cool or read about it on an internet forum. Either way it has no special 'capabilities' and may not even be needed.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 3 Old 05-25-2014, 07:56 AM
vincentfam's Avatar
Liked: 24
The EDA-FT08100 is a drop amplifier that increases cable signal strength for multiple televisions, with active no loss return. Under ordinary circumstances, if you have cable service feeding multiple tvs, phone, and internet modems, your cable signal will drop if you are using a regular ordinary splitter. Under these circumstances, the signal actually decreases which may impact your tv, internet and phone service. This drop amp increases the signal (in dBs) to maintain the integrity and quality of the signal, and has eight outputs.
The active return with no loss ensures that your signal from your devices to your cable company (for example charter on demand) will have no problems. However, if you use this device, you will need to put cable terminators on cable outlets that you are not using to avoid sending signals outside of your home that may interfere with your neighbor's cable service.
See this website for more information: http://www.dropamp.com/
I have had this device for over ten years without any problems.
Good luck,
Vincentfam
vincentfam is offline
Reply Cable, Digital Cable - Non-HDTV
