Amplifier or Filter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-09-2014, 01:08 PM - Thread Starter
Danmarino's Avatar
Hello,
I work in a environment where I need to use a filter or amplifier on the incoming cable signal outside the building that will not allow a return signal on the coax line. I will be bringing the cable into a locked metal box on the outside of the building and install this filter or amplifier then run the rest of the cable to the TV located inside the building. Does anyone know of a band pass filter or amplifier that I can buy that is truly one way and will not allow a return signal.
Danmarino is offline
post #2 of 7 Old 06-09-2014, 03:13 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Have you checked with the cable provider? They probably can address the technical issue(s).
Maybe if you provide more info about your environment and the reason(s) you want/need the return signal blocked, someone may be able to address the question properly.
Ratman is offline
post #3 of 7 Old 06-09-2014, 04:47 PM - Thread Starter
Danmarino's Avatar
I work in a high security environment and it is a requirement if I am to bring cable TV in I must block the return path.
This will just be coax cable connected to a TV with no cable box. I have talked to the cable provider and they don't have
or sale any such filter or amplifier.
post #4 of 7 Old 06-09-2014, 07:57 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
At one time they were even harder to come by because they could be used to keep a stolen cable box alive by blocking the return communication in the 6 to 13MHz band. More common are filters that pass 5-13MHz and block 15-45MHz. Two bucks and change: http://www.pctstore.com/High_pass_filter_PCTHPF50NNH_p/pcthpf50nnh.htm cool.gif
EDIT: Odds are you'll need a set top box too as most cable systems are ridding themselves of Analog and Clear QAM. mad.gif
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 7 Old 06-10-2014, 06:12 AM
Ratman's Avatar
Liked: 1029
Either way... what (or why) is considered a "security risk" to your environment with a cable provider's return path? Just curious.
If I worked in your security department, I'd be more concerned about what was coming IN as opposed to worry about what's going OUT (TV only... not internet, that's understandable). smile.gif
Ratman is offline
post #6 of 7 Old 06-13-2014, 11:11 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
How about having the cable box in the locked metal box, then bringing component cables + stereo sound into the secured building? As far as I am aware, component video and stereo sound are strictly one-way ports. HDMI, on the other hand, does some communications back to the source device, though I doubt it would communicate back much more than the HDCP handshake and whether the display device is on.
My very humble setup:
Spoiler!
Mark12547 is online now
post #7 of 7 Old 07-15-2014, 05:36 AM
RCbridge's Avatar
Quoted: 16 Post(s)
I don't understand the reason if you are only using a TV no STB?
You could use a di-plex filter feed the TV with the high side.
RCbridge is offline
Reply Cable, Digital Cable - Non-HDTV
