10 meter (33 feet) hdmi cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-25-2014, 11:48 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
What cable do I need for this distance, I know only that in a certain distance there is a signal loss.
soler37 is offline
post #2 of 11 Old 06-25-2014, 01:31 PM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
My guess is that you would need an active signal booster type cable, like RedMere.
I googled it and a few popped up.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 11 Old 06-25-2014, 01:36 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1180
This is suggestion that popped up when I googled.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Ratman is online now
post #4 of 11 Old 06-26-2014, 06:34 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
You can lead the horse to water, but you can't make it drink
post #5 of 11 Old 06-26-2014, 07:18 AM
Ratman's Avatar
Liked: 1180
It's easier to find a drink if you provide the horse a link.
post #6 of 11 Old 06-27-2014, 02:02 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
That is hilarious...
soler37 is offline
post #7 of 11 Old 06-27-2014, 06:35 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I guess I am not an enabler.
post #8 of 11 Old 06-27-2014, 07:13 AM
Ratman's Avatar
Liked: 1180
Enabler?
LOL! The guy wants a 30' HDMI cable. Not an alcoholic beverage or a toke off the pipe.
And... you did say you were guessing.
post #9 of 11 Old 07-03-2014, 08:23 AM
Garet Jax's Avatar
I bought 3 60 foot redmere cables from Monoprice and 2/3 did not work. I love Monoprice, but was told Redmere cables are really only to be used connecting a source directly to a display (and not through an intermediary like a receiver). You might want to try Series-FE, Series-1 or Tartan cables from BJC.
I bought 6 Series-FE cables and 1 Series-1 cable and they have all worked great.
The only consideration is that Series-FE are only high speed certified upto 15 feet and the Series-1 cables are only high speed certified upto 25 feet. These by the way are the longest certifications for high speed cabling I was able to find and the reason I bought from BJC.
Garet Jax is offline
post #10 of 11 Old 07-03-2014, 11:20 AM
Ratman's Avatar
Liked: 1180
Just gotta ask...
You did know that Redmere HDMI cables are "directional", right?
Also... I didn't see a reference to a 60' HDMI from your link. Anything to help that is more descriptive?
And I can't find a 60' HDMI Redmere cable on the Monoprice site.
Any info would be helpful for those interested. Thanks!
post #11 of 11 Old 07-03-2014, 11:34 AM
Garet Jax's Avatar
Just gotta ask...
Thanks for keeping me honest :-)
Yes I did know that Redmere cables are directional.
I couldn't find it on a search either. I had to go back to my order number to get the part number and then did a direct search on that.
When I told the techs at Monoprice that I wanted to use Redmere cables for connecting sources to a receiver they suggested I use the Premium 24 AWG cable instead.
PS - Because of the high speed certification distance of 25 feet, I ended up moving my consoles into the rack and ended up moving the rack closer to the TV. I was able to use a 25 foot Series-1 cable to connect one TV directly and a monoprice HBaseT HDMI extender to get the signal to the TV upstairs. In essence I got around the need for a 60 foot HDMI extension in all but one case. In that one case, I used an extender.
PPS - I have had a terrible time getting HDMI things right in my rack. I have had lots of problems with video and audio. I have tried many things and moved the rack for a few reasons. I replaced every HDMI cable in the rack. The last set of changes (physically moving rack, putting it on its own dedicated circuit and replacing all HDMI cables) seems to have done the trick. Keeping fingers crossed, but so far so good.
Reply Cable, Digital Cable - Non-HDTV
