Dilemma with tv above fireplace. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-20-2015, 07:13 AM - Thread Starter
reap76's Avatar
Liked: 0
Ok, here is my dilemma. I want to mount my tv over the fireplace, but the coax is on an adjacent wall approximately 30 feet away. Initially, my wife (against my better judgement) decided that the tv would never go over the fireplace and that it was better in an entertainment center and thus the reason that I don't have a coax above the fireplace. What I do have above the fireplace is 3 speaker wires(for sound bar), an additional speaker wire and 2 cat 6 cables. All my audio/video wiring run to a closet in the basement which will one day be the media closet. I was looking into ir receivers/transmitters/blasters and think this would be the best method. Can I terminate my own audio jacks and what would be the best way to implement this? That would cover the cable box. I was thinking of using Cat6 to HDMI converter to for video from TV to Cable box. Thoughts/Suggestions? Thank you in advance for all the info.
reap76 is offline
post #2 of 8 Old 11-20-2015, 07:59 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Respectfully, I'm with your wife on this.
I have no understanding why people insist on mounting a TV over a fire place. It is incredibly uncomfortable, or I find it uncomfortable to view for any length of time when one assumes a normal seating position. It looks good in architectural magazines and printed advertisements though and I guess it's ok if your standing up to watch.
I use an IOGEAR GW3DHDKIT to send HD from my cable box to a 50" plasma TV in an upstairs room and it works very good; very happy with it. It even accepts commands from the cable box remote. Here's a link to the product: https://www.iogear.com/product/GW3DHDKIT/
b curry is offline
post #3 of 8 Old 11-20-2015, 08:51 AM - Thread Starter
reap76's Avatar
Liked: 0
Thanks I'll check this out. The problem is that she has changed her mind and decided that it needs to go over the fireplace. We have altered the entire great room to accommodate this setup. Now to get the TV working
reap76 is offline
post #4 of 8 Old 11-20-2015, 08:54 AM - Thread Starter
reap76's Avatar
Liked: 0
PS.. My better judgement was not that the TV should be over the fireplace, but that eventually she would change her mind and want the tv above the fireplace.
reap76 is offline
post #5 of 8 Old 11-20-2015, 09:22 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
As I said, I've been very happy with the IOGEAR unit.
We often set up a TV or a projector outside in the summer months to watch a movie or sports while enjoying the patio or a BBQ. The IOGEAR unit allows us to do that while having access to the cable box or Blu-ray player inside the house. It's also very easy to setup.
Good luck!
b curry is offline
post #6 of 8 Old 12-22-2015, 04:53 PM
Liked: 1
Can't help with your actual question and it does sound like you are set on the TV over the fireplace but...
It's really bad to have it over the fireplace.
1. It will be far too high for a good viewing angle
and
2. If you use the fireplace the TV will be exposed to excessive heat and could shorten the life of the TV.
Good luck.
brownSys is offline
post #7 of 8 Old 06-24-2016, 08:30 AM
Liked: 0
Oh wow! This is like magic! Never heard of something like this, thank you for that. Here's an updated link for it: https://www.iogear.com//product/GW3DHDKIT/
dambo29 is offline
post #8 of 8 Old 02-21-2017, 09:22 AM
Thats nice. Glad I found this.
Lightnin1213 is offline
Reply Cable, Digital Cable - Non-HDTV
