need help find HDMI cable - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Otto Pylot
  • 1 Post By Ratman
  • 1 Post By Ratman
post #1 of 9 Old 05-28-2016, 05:58 PM - Thread Starter
Quoted: 32 Post(s)
Liked: 1
so in the way my new projector epson 2040 so i will connect to my pc vga card
so i need something good value for money at least 5 m not more than 50$
Ahmed Mohmed is offline
post #2 of 9 Old 05-29-2016, 08:32 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
You should really ask this question in the HDMI forum because you will get a better response. However, at 5m (15') any passive, high speed HDMI cable will work depending on the type of signal you are trying to push. 4k, 4:4:4 @60Hz is very problematic for most. Anything other than that, the above mentioned cable should work just fine. Be mindful of bend radius and wire gauge. You can also use an active cable with Redmere technology. There is nothing magical about an active cable other than you can run it at longer lengths than a passive cable because of the error correction and timing chipsets in the sink end (tv side).
Ahmed Mohmed likes this.
Otto Pylot is offline
post #3 of 9 Old 05-29-2016, 02:50 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Here's the question?
Does your PC have a HDMI output or is it VGA.
1) No HDMI on PC video card? Look to get a new card.
2) PC has VGA out only? Then just use VGA from PC to the projector since it has a VGA input.
Ratman is offline
post #4 of 9 Old 05-31-2016, 04:46 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 1
yes my pc card has a hdmi output and i want connect my new projector 2040 to my pc with hdmi so kind of cable you advice
post #5 of 9 Old 05-31-2016, 05:36 AM
Ratman's Avatar
Liked: 1191
Ratman is offline
post #6 of 9 Old 05-31-2016, 08:08 PM - Thread Starter
Quoted: 32 Post(s)
Liked: 1
thanks is there is any other product from other company you advise like monster or Audioquest or Accell
or thiscable is good and will give me great picture
post #7 of 9 Old 05-31-2016, 08:57 PM
Otto Pylot's Avatar
Liked: 1043
Monster and Audioquest make good cables but they are typically way overpriced. There are other cables that perform just as well for a lot less money. It's all marketing and slick packaging. If the cable can sufficiently pass the signal without any issues then that's as good as you're going to get. The cable can not make a digital signal (audio or video) any better than it already is.
post #8 of 9 Old 02-21-2017, 08:45 AM
Lightnin1213 is offline
post #9 of 9 Old 02-21-2017, 08:46 AM
nmb
Reply Cable, Digital Cable - Non-HDTV
