Screen shift to the left with 24hz (DP to HDMI converter). - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-27-2016, 02:01 AM - Thread Starter
hdejongh's Avatar
Hello,
I have a Dell Optiplex 3040 with a r5-340x, both adapters feature 1 DVI port and 1 DP port.
I use this computer as a media station and it is connected to 2x a U2715H and a projector: Sony HW40ES.
As the projector only supports HDMI i have bought a Delock Adapter Displayport 1.2 male > HDMI female 4K 60 Hz Active.
If i force the videocard into 1080p/24f my screen shifts to the left.
So about 10% of my screen which should be left is suddenly at the right side of my screen.
This happens only through the HDMI connection. So i can replicate the same issue on my U2715H if i connect it through HDMI instead of DP.
If i use 1080p/50hz or 1080p60hz there is no problem.
What am i doing wrong?
hdejongh is offline
post #2 of 2 Old 12-27-2016, 11:59 PM - Thread Starter
hdejongh's Avatar
Originally Posted by hdejongh View Post
Hello,
solved:
the delock converter doesn't support 24hz.
so i got a club-3d converter which works flawless!
hdejongh is offline
Reply Cable, Digital Cable - Non-HDTV
