where to buy 1 ft. to 1.5 ft gold plate toslink cable? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By zaphod7501
post #1 of 5 Old 03-02-2017, 12:44 AM - Thread Starter
happy hopping's Avatar
Quoted: 67 Post(s)
http://www.primecables.com/p-331946-...70mm#sku331946
I want a cable that looks pretty much like the above, but only 1 to 1.5 ft. long. w/ the housing gold plated and preferred braided.
I already check monoprice, they don't have it
happy hopping is offline
post #2 of 5 Old 03-02-2017, 01:12 AM
Jaurhead's Avatar
Quoted: 168 Post(s)
Liked: 120
My search turned up the same results you got, I'm sure:
Gold plating seems to start at 3 feet, not less than. At 1.5 feet, I found the following (w/o plating):
The Monoprice Option
5 star rating with almost 2000 reviews...for less than $2.
Or a few from Parts Express.
Another option would be to go with a custom make from Blue Jeans Cable, though it doesn't look like they use gold plating. I haven't purchased from BJC, but I've heard nothing but glowing reviews around the forums.
Mr. Pibb > Dr. Pepper > Everything Else
7.1.4 - Marantz SR6011 - LG B6 - HTD Level 3 - PSA S3000i
Oppo 203 - PS4 - Xbox One S - Roku Ultra
60 UHD and counting...
Jaurhead is offline
post #3 of 5 Old 03-02-2017, 05:32 PM
Bill Shenefelt's Avatar
Quoted: 103 Post(s)
Liked: 42
You want gold plating because?? Gold is not a great conductor, just an oxidation resistant material. I really do not know what gold plating would offer as a coating unless it is a contact surface coating to precludes oxidation of the two contacting surfaces, reducing conduction. Also I do not understand what gold does to help optical signal transmission. Is this just for appearance?
Bill Shenefelt
http://sheneskillies.com
william.shenefelt@verizon.net
Bill Shenefelt is offline
post #4 of 5 Old 03-02-2017, 05:43 PM
bluemoon737's Avatar
Quoted: 1242 Post(s)
Liked: 1585
I'm hoping the inquiry is a joke...the signal path is OPTICAL so gold plating on what is normally plastic that "holds" the connection in place will do absolutely nothing to improve anything (other than perhaps their bottom line). Please tell me your inquiry is a joke...PLEASE!
Sony XBR75Z9D
Yamaha RX-A3050
OPPO UDP-203
bluemoon737 is offline
post #5 of 5 Old 03-03-2017, 08:11 AM
zaphod7501's Avatar
Quoted: 89 Post(s)
Liked: 79
If it's for color coordinating, he could buy a roll of heat shrink tubing and make it almost any color desired.
bluemoon737 likes this.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
Reply Cable, Digital Cable - Non-HDTV
