Need help fixing a Sega Master System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-30-2017, 07:49 AM - Thread Starter
Liked: 0
Hi, I don't know where to post this so I'll try it here. I'm working on a model 1 master system and it had no video. So I took it apart and replaced all capacitors and tested the voltage regulator, which was fine. This time it gets video but only once in a while, ans it's all garbled up. I tested it with RF and then bought a new composite cable for it, hoping that I would see good video, but it was the same result. Anyone know what the problem is and how I can fix it? Thanks.
bluemetal04 is offline
Reply Cable, Digital Cable - Non-HDTV
