Dish 510 Install - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-13-2004, 07:30 PM - Thread Starter
PaulM9999's Avatar
I'm looking to help a friend with a Dish 510 install and could use some advice.
She has a Dish Network, dual LNB pizza dish, with one coax wire coming into the TV room. They want to use their existing standard receiver as well as the new 510 on the same television. Is there a multiswitch I can buy which would allow her to split the signal to run into both receivers?
Paul
PaulM9999 is offline
post #2 of 5 Old 02-13-2004, 07:41 PM
Scooper's Avatar
No.
Run a 2nd coax from the Dish to the room. You should get a TWIN LNB (or TWIN DishPro LNB) - Have both cables going to the location where the TV is.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 5 Old 02-15-2004, 06:44 PM - Thread Starter
PaulM9999's Avatar
Thanks for the quick response. She uses the second coax from the Dual LNB to connect a bedroom receiver. Is there a way to use 3 receivers on a dual LNB dish?
post #4 of 5 Old 02-15-2004, 06:53 PM
Scooper's Avatar
In that case (what you probably have is a TWIN, not a Dual LNB) - replace the TWIN LNB with a QUAD LNB and pull another cable to the 3rd receiver location. Or, you can simply deactivate one of the receivers and put the 510 in its place.
Scooper is offline
post #5 of 5 Old 02-15-2004, 07:14 PM - Thread Starter
PaulM9999's Avatar
Thank you Scooper. I was hoping to get this done without having to run more coax, but it sounds like I don't have much choice.
Thank you,
Paul
Closed Thread Cable, Digital Cable - Non-HDTV
