2 DirecTv accounts at the same address? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-04-2004, 03:21 PM - Thread Starter
Shark73's Avatar
Can you have two DirecTv accounts at the same address?
Jim
Shark73 is offline
post #2 of 12 Old 08-04-2004, 07:26 PM
bfoster's Avatar
Sure, but why?
bfoster is offline
post #3 of 12 Old 08-04-2004, 11:19 PM
restart88's Avatar
In fact, I think if you have more than 5 receivers you *must* get a 2nd account (unless they grant you an exception based on unusal circumstances like you got 5 kids and they have separate bedrooms). But I could be wrong.
restart88 is offline
post #4 of 12 Old 08-05-2004, 08:36 AM - Thread Starter
Shark73's Avatar
Originally posted by bfoster
Sure, but why?
I want the new HD network feeds from D*.....meaning I may have to move to a buddy's house in a white area.
Shark73 is offline
post #5 of 12 Old 08-05-2004, 08:43 PM
David Richardson's Avatar
restart88
We have 16 receivers on one residential account with issues. I deal with large home all the time and they don't care. Unless....................
Shark
Don't think so but you can try. Make sure you set up that second account with a cell phone number or second line number to the 'new' house phone number.
Dave
David Richardson is offline
post #6 of 12 Old 08-05-2004, 10:43 PM
CCarncross's Avatar
You know in Cleveland you can get the 4 main networks +PBS, maybe both of them, in HD OTA , why would you need to pull a scam?
CCarncross is offline
post #7 of 12 Old 08-06-2004, 12:16 PM - Thread Starter
Shark73's Avatar
If I could get an outdoor antenna then I wouldn't bother with the HD channels from D*. However, I live in a townhome and it's like pulling teeth to get approval from the association. The roof is 100% off limits since it's maintained my the association. I could put the antenna on a poll, but it wouldn't see over the house toward Parma and the towers.
The only channel I really have trouble with is NBC. I have no signal at all for NBC using an indoor antenna.
Shark73 is offline
post #8 of 12 Old 08-06-2004, 04:21 PM
CCarncross's Avatar
SO where theheck is your Sat dish? You could always get a Terk stick type, I have heard very good things about them...
post #9 of 12 Old 08-07-2004, 12:04 AM
restart88's Avatar
I've heard good and bad reports about those clip ons. But I actually do use them myself! At one home I get a fairly strong signal for nearly every channel available. At another home, the best I can term the reception is "better than nothing during an outage."
I used a Phillips powered by the receiver at my main home. The less impressive one is a Terk, but it is in another city which may account for the difference. It could be due to some sort of electrical interference. But try it and see if it works for you or not. You can always return it to the store if it doesn't work and if you find an open box they can be as cheap as $25.
However, I have no clue how good they are for HDTV, since I don't have it yet myself.
post #10 of 12 Old 08-07-2004, 05:26 AM
Scooper's Avatar
All you need is a "long enough" pole (not poll) and you should be able to see over the roof. Or you could put the pole/antenna at the front of the townhouse.
As far as putting the antenna on the roof - sure, they maintain it - but it is still YOUR exclusive use area. If they complain about it - let the FCC decide who's right and wrong. Even if you lose, you still have 30 days after the decision to remove it. Put it up there, and file the complaint at the FCC, and see what happens.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #11 of 12 Old 08-07-2004, 08:36 PM
cktb2793's Avatar
I have 6 receivers on my account right now and the last 4 were added online with no problem.
cktb2793 is offline
post #12 of 12 Old 08-08-2004, 02:31 PM
harley1's Avatar
You can "move" and call that your service address.
Tell D* your home address is your mailing address,for your bills.
They will ask if your receivers are hooked up to a phone line.
Say yes and leave your receivers connected to your phone line.
Remember your service address determines your local sports rsn and blackouts.
harley1 is offline
Closed Thread Cable, Digital Cable - Non-HDTV
