One Hughes receiver, 2 TVs, easy question..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-10-2000, 04:30 PM - Thread Starter
KKemp's Avatar
Helped my dad install his new system and ran into a question. 2 tv's, one receiver. The second tv is hooked up by coax from the "tv out." The second tv gets satellite reception fine on channel 3 (this is an older tv with only 1 coax input). However, when the main tv is watching satellite, or whenever the satellite receiver is on for that matter, I am unable to get local reception on tv #2. When the receiver is turned off local reception on tv #2 is perfect. As it is now if someone is watching satellite on tv 1, tv 2 will only be able to get the same satellite program but no local. Not what we had in mind.
I'm assuming I will need a switch of some kind to distinguish the two different frequencies. I was told at the electronics store that I would be able to get satellite on channel 3 and local channels just by turning the knob(!). I told you it is an older tv. Does somebody have an easy fix for this??
KKemp is offline
post #2 of 5 Old 06-10-2000, 05:03 PM
Kevin T's Avatar
Press the "Input" button on the remote to switch between TV and Satellite on the second TV. Make sure the Input button is enabled in the advanced setup menu (is should be by default). This is all explained in the owner's manual. Did you read it ?
Kevin T is offline
post #3 of 5 Old 06-10-2000, 05:57 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
Or you could just put a simple A/B switch at TV 2. Cable in to A, satellite in to B.
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #4 of 5 Old 06-11-2000, 10:56 PM - Thread Starter
KKemp's Avatar
Mike, thank you for the input. Thought I may need a a/b switch.
Kevin, yes I read the book. Did you read my post? Do you really think a tv with a knob to change channels actually has a remote that I could use to change the input?!? You'll also see that the only input into the second tv is a single coax input.
KKemp is offline
post #5 of 5 Old 06-11-2000, 11:41 PM
Kevin T's Avatar
I understand the second TV is connected by coax and does not have a remote. I have a 20+ year old 13" TV (knobs for tunning) connected to the RF output of my Huges E-11. The Hughes remote has an Input button that switches the coax output between satellite and the TV/Cable input. The switch in built into the Hughes receiver, you don't need an a/b switch. See pages 3-2 and 7-10 of the manual.
Kevin T is offline
Closed Thread Cable, Digital Cable - Non-HDTV
