SAT-W60 - AVS Forum | Home Theater Discussions And Reviews
Old 03-08-2001, 08:29 AM - Thread Starter
kevin44's Avatar
I am interetsted in how this dual tuner works in this unit. I can watch one show and tape a different channel with the built in Tivo? Do you need two access cards or something?
kevin44 is offline
Old 03-08-2001, 09:23 AM
Chris Gerhard's Avatar
The SAT-T60 is the model number for the Sony DirecTV with TiVo. The SAT-W60 I believe is the model number for their Ultimate TV and if so, only one access card is required to use both tuners and record one channel while watching another. The SAT-T60 TiVo does not currently support two tuners but supposedly will in the near future and it will also only require one access card.
Chris
Chris Gerhard is offline
Old 03-08-2001, 11:49 AM
Kevin,
A new site dedicated to the UltimateTV is located at:
http://63.87.244.105/cgi-bin/ikonboard/ikonboard.cgi
The users seem happy so far.
Chris
Old 03-08-2001, 10:49 PM - Thread Starter
kevin44's Avatar
You are right on the model #. Has anyone used one of these?
kevin44 is offline
Old 03-09-2001, 11:40 AM - Thread Starter
kevin44's Avatar
Thanks Chris.
kevin44 is offline
