Directv receivers with component output? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-11-2004, 09:03 AM - Thread Starter
Johnny Bax's Avatar
Anyone ever heard of such a beast? My current RCA Directv receivers are S-Video output only. Would like to upgrade to component video output.
"If it sounds good, it is good!"
Johnny Bax is offline
post #2 of 13 Old 11-11-2004, 09:31 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Unless you're trying for HD, the difference between component and S-Video is negligible (if any).
If you are intending to get HD, you will need an HD ready/capable TV and a new DirecTV receiver that is HD. Most all HD receivers have Component video outputs.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 13 Old 11-11-2004, 09:40 AM - Thread Starter
Johnny Bax's Avatar
Hi Ratman,
Not trying for HD yet, but that time will come, too.
Are you sure the PQ would be negligible on SDTV with component vs. S-Video? Isn't directv digital service broadcast in 480i? Every other time I've gone from S-video to component(say, with a DVD player), the difference between the two connections have been quite remarkable. At least to me.
But, the question still remains.....does anyone make a non-HD directv receiver?
post #4 of 13 Old 11-11-2004, 09:57 AM
Ratman's Avatar
Liked: 1191
Yes.
Yes... and so is a non-progressive DVD player.
That is due to the fact of the quality of source material.
Tried a few searches and came up empty. There was an RCA that's been discontinued.
You may be better off just buying an HD receiver and let it downconvert to 480i.
edit:
found this:
http://shopping.yahoo.com/p:Hughes%2...0TV:1991392349
And this...
http://www.receiver-ratings.com/items/5708529129.html
Ratman is offline
post #5 of 13 Old 11-11-2004, 10:44 AM
william_h's Avatar
or you can go to radio shack and buy the 100 dollar rca receiver with component outs its silver i seen it their the other day..
or you can check your local satellie dealer and buyone from them half price in the 29.99 to 49.99 range.
just be sure to get the model number of the one thats at the rat chack.
william_h is offline
post #6 of 13 Old 11-11-2004, 10:50 AM
Ratman's Avatar
Liked: 1191
Radio Shack is now a "Dish" reseller. Although, you may still find a DirecTV receiver laying around in one of them.
Ratman is offline
post #7 of 13 Old 11-11-2004, 11:33 AM - Thread Starter
Johnny Bax's Avatar
Thanks guys.
post #8 of 13 Old 11-11-2004, 10:03 PM
Kevin T's Avatar
The RCA DRD486RH and Philips DSX 5540 both have component ouput. They are both recently discontiuned, but still available.
Kevin T is offline
post #9 of 13 Old 11-12-2004, 07:23 AM
jackshakes's Avatar
there's a couple of both models listed above on ebay for pretty cheap ...
if you get one post back here with how well you like it ... i may consider getting one (or two) if the picture is that much better.
jackshakes is offline
post #10 of 13 Old 11-16-2004, 09:37 PM
Kevin T's Avatar
The Hughes HAH-SA is another discontiuned model with component out. I have the Philips and Hughes, but don't have a TV with component input.
Kevin T is offline
post #11 of 13 Old 11-17-2004, 12:51 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
The Samsung SIR S-75 is a SD D* receiver with component video outputs and is available here.
Vin
Vin is offline
post #12 of 13 Old 11-18-2004, 09:54 AM
leesweet's Avatar
Huh. The S75 is supposed to be obsolete. Must be old stock. Not to say it's a bad STB. I've got two of them I replaced with D10s to get serial remote control (for Replays) and the D10s don't have component... :D
-Lee (See my profile for equipment.)
leesweet is offline
post #13 of 13 Old 11-18-2004, 12:35 PM
DanHuff's Avatar
The Samsung S75 also has Optical sound output for DD, make sure you get this also! The box is rock-solid and very fast.
DanHuff is offline
Closed Thread Cable, Digital Cable - Non-HDTV
