Cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-31-2007, 01:18 PM - Thread Starter
abredt's Avatar
I need cables - S-video, composite, etc. Momoprice has lots of choices. Do I get the cheapest, middle price???
Also - for composite, is the yellow cable different from the red?
Thanks, CB
abredt is offline
post #2 of 8 Old 01-31-2007, 06:26 PM
PowermanFla's Avatar
As a professional installer i would say go with the less expensive if you have a regular TV, and/or a non HD cable box. but if your hooking up a $5000 LCD and are paying an extra $20-$30 a month for HD programming use the midgrade cable at the least, ...as for the yellow RCA its no different then the red or white...yellow denotes VIDEO when red/****eare audio
PowermanFla is offline
post #3 of 8 Old 01-31-2007, 11:31 PM
jmalt's Avatar
If you are looking for a great deal on all types of cables, check out showmecables on the web. They are a really knowledgeable company, and they offer all types of cables at great prices.
jmalt is offline
post #4 of 8 Old 02-01-2007, 06:33 AM
Bluto17's Avatar
Quoted: 29 Post(s)
Liked: 43
Monoprice is so inexpensive, I don't mind paying a little more for their better quality stuff. But, Powerman makes a good point on the SD vs HD display.
With Monoprice's prices and quality, they have a lifelong customer in me. I just saved hundreds of $ wiring my theater and rec room by using monoprice's products.
Bluto17 is offline
post #5 of 8 Old 02-07-2007, 07:09 PM
hometheaterguy's Avatar
Settle for nothing less then silver interconnects from www.kimber.com period.
A veteran is someone who, wrote a blank check Made Payable to 'The USA, ' for an amount of 'up to and including their life.'
hometheaterguy is offline
post #6 of 8 Old 02-08-2007, 08:44 AM
All4Heels's Avatar
Sorry for my ignorance, but exactly what hdmi cable from monoprice do I need to connect my Mits HDTV to the STB. Thanks!
All4Heels is offline
post #7 of 8 Old 02-08-2007, 09:21 AM
Bluto17's Avatar
Quoted: 29 Post(s)
Liked: 43
I'd go with something the 24-gauge (24AWG) range from this page:
http://www.monoprice.com/products/su...d=10240&style=
Get the shortest length you can - 6 feet (Part ID 2219) works for most if the STB is just above or below your TV.
http://www.monoprice.com/products/pr...ormat=2&style=
Bluto17 is offline
post #8 of 8 Old 02-08-2007, 11:21 AM
All4Heels's Avatar
Thanks Bluto, just placed an order.
Reply Cable, Digital Cable - Non-HDTV
