What the heck is he difference between a 7.5db and 12db cable splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-03-2007, 12:20 AM - Thread Starter
jjmancini's Avatar
Hey Everyone!
What the heck is he diff between a 7.5db and 12db cable splitter?
I just got a new house and when the comcast guy came to set-up internet, he unplugged by buit-in 8 way splitter that 12db and put in a 5 way splitter that was 7.5 db. What is the difference? Should I take one over the other?
Any help would be great!
jjmancini is offline
post #2 of 9 Old 02-03-2007, 01:26 AM
Joxer's Avatar
Thats normal. A splitter with more outputs will have more loss, each 3db is about 1/2 the signal. Use the least output version as you can for least loss or you may also need a low-noise cable amplifier to make up for the loss.
Joxer is offline
post #3 of 9 Old 02-03-2007, 01:36 AM - Thread Starter
jjmancini's Avatar
oh ok... that makes sense. Shouls I split off my cable modem before I split to TV? Thanks so much for the help!
post #4 of 9 Old 02-03-2007, 01:39 AM
mterzich's Avatar
An 8-way splitter will spilt the power so that each output usually gets 1/8 the power (12 DB) and a 5-way splitter will split the power so that each output usually get 1/5 the power (7.5 DB). Therefore the less number outputs, the greater the signal strength.
mterzich is offline
post #5 of 9 Old 02-03-2007, 06:52 AM
RCbridge's Avatar
Quoted: 16 Post(s)
How many splits do you need?
If 5 will do the fewer the better.
RCbridge is offline
post #6 of 9 Old 02-03-2007, 07:43 AM
MrMike6by9's Avatar
The modem and the cableco box will be the most sensitive to signal levels. For best performance (IMO) they should be "as close as possible to the pole". My line-in has a 2-way on the outside of the house with the cable modem on one leg and the other to the LR to another 2-way splitter. One leg goes to cableco box, the other to an broadband drop amp that feeds the SD side of the LR TV, Tivo, VTR, & 1 DVDR through a switcher so the coax side of the cableco box can feed the DVDR and the BR and also patches in the OTA roof-top antenna. In the BR there is a 2nd DVDR that has coax pass-through for the BR TV.
YMMV
"Typos are very important to all written form. It gives the reader something to look for so they aren't distracted by the total lack of content in your writing."
- Randy K. Milholland
MrMike6by9 is offline
post #7 of 9 Old 02-04-2007, 09:57 PM - Thread Starter
jjmancini's Avatar
Wow great explanation guys! Thanks for clearing that up!
i will go ahead and split off my Cable modem then before my basic cable. Thanks again!
post #8 of 9 Old 02-05-2007, 06:38 AM
Bluto17's Avatar
Quoted: 29 Post(s)
Liked: 43
Dumb question - if you have an 8-way splitter, but cap off the unused splits at the splitter, will that improve the signal through the other uncapped splits? For example, using 5 splits of an 8-way splitter and capping off the three unused splits.
Bluto17 is offline
post #9 of 9 Old 02-06-2007, 01:35 AM
Joxer's Avatar
Capping unused splitter outputs is a good idea to prevent noise pickup. However it won't change the fixed losses. Only a splitter with fewer outputs will reduce the loss.
Joxer is offline
Reply Cable, Digital Cable - Non-HDTV
