Camera System Help Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2007, 12:40 PM - Thread Starter
Anemic Dog's Avatar
We have an outdoor camera system connected to our cable system. A crucial piece of this is a Channel Vision tier trap filter, which takes out channels 70-79.
Problem is, our reception on the remaining analog channels isn't as good as it should be, and we were hoping to find a filter that didn't take out so many channels.
Any suggestions for these problems? The guy who did the low voltage on our home is angry with our builder and I fear that I'll have to make any changes myself.
Thanks for any help.
Anemic Dog is offline
post #2 of 3 Old 03-07-2007, 11:31 AM
hometheaterguy's Avatar
You could run a dedicated line for the camera and use the existing line for video and eliminate the trap. Those filters are notorious for making the picture grainy.
A veteran is someone who, wrote a blank check Made Payable to 'The USA, ' for an amount of 'up to and including their life.'
hometheaterguy is offline
post #3 of 3 Old 03-07-2007, 11:55 AM
kenglish's Avatar
Liked: 40
The "Q" (quality, or sharpness of the cutoffs) of the filter, is determined by how many stages, or levels, of filtering are used. So, a filter with sharper cutoff points will be larger, and cost more.
You can check out "Channel Deletion Filters" at sites like:
http://www.blondertongue.com/headend/cef.pdf
http://www.microwavefilter.com/specialappfastrap.htm
http://www.cefilter.com/products/dis...odID=22&CatID=
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Reply Cable, Digital Cable - Non-HDTV
