Comcast HD Channels & Firewire Record - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-03-2007, 09:36 AM - Thread Starter
itr2401's Avatar
Hiya all,
I was wondering if anyone else is having an issue with recording programs via firewire on Comcast in the Bay Area.
I'm fully aware that I can't record channels which have 5C encryption enabled, however some of the channels which are supposed to be in the clear, are also not being recorded citing that they have 5C encryption enabled. When I check the firewire status for that channel it is shown as being 5C off.
The main channel I am having the issue with is Channel 705 (KPIXDT). I record the firewire programs using the firestb application through to Windows MCE.
I know that this used to work as I have several HD recording off this channel and the others (702-728).
Anyone have any ideas or suggestions?
itr2401 is offline
post #2 of 7 Old 03-03-2007, 01:27 PM
eric.exe's Avatar
Quoted: 16 Post(s)
eric.exe is offline
post #3 of 7 Old 03-04-2007, 02:21 AM
samsung hd's Avatar
comcast are the next napster
samsung hd is offline
post #4 of 7 Old 03-08-2007, 10:23 PM
Haloplaya's Avatar
I have noticed lately that Comcast upgraded yet again, the Firmware on most HD DCT's.
They have also made most of the digital lineup NON-5C Encrypted, so you should be able to record any channel.
Something that may be different, is the Resolution they are sending the files at now(544x480), and used to be the full (720x480) for standard def. HD Channels should record at 720P and or 1080i.
I do capturing ALOT myself through firewire.
Haloplaya
Haloplaya is offline
post #5 of 7 Old 03-16-2007, 06:54 PM
Dirtyturbin's Avatar
Sorry to rebring this post to life but I just got a 3416 and am wondering if I can record via firewire or not? Thanks in advance.
Dirtyturbin is offline
post #6 of 7 Old 03-16-2007, 07:09 PM
bfdtv's Avatar
At the very least, you can record the local channels via Firewire. In many areas, the digital cable channels carry a 5C "copy once" flag -- you cannot record those via Firewire.
bfdtv is offline
post #7 of 7 Old 03-17-2007, 07:09 AM
Thaks for the reply bfdtv is there an idiots guide? Thanks!!
Reply Cable, Digital Cable - Non-HDTV
