normal coaxial cable vs rca cable ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-28-2007, 05:48 PM - Thread Starter
guardianflash's Avatar
I know this is such a noob question, but I googled and still can't find an answer. Is RCA cable(the yellow, red, white) better than coaxial cable?
Is Coaxial cable(black) the cable that comes with the cable box? Not sure if that is call coaxial. I connected both from my cable box to my hdtv and couldn't decide which is better one to go for. I'm been using the black cable for many years. I use them for my old VCR, cable box, tv etc.
guardianflash is offline
post #2 of 14 Old 03-28-2007, 05:51 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 456
Generally, they are all coaxial in construction and differ mostly in the thickness of the conductors and the type of connector. Otherwise the same.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 14 Old 03-28-2007, 05:53 PM - Thread Starter
The only thing I notice is with the black one the color is more and with rca the color is not as saturated.
post #4 of 14 Old 03-29-2007, 06:20 AM
whoaru99's Avatar
Liked: 69
Some of that could be related to the cable, but it's probably more a factor of what device is demodulating the RF CATV signal into the (composite) video signal and how well your TV deals with external composite video input.
When using the black coax all the way to the TV, your TV tuner is demodulating the RF signal into the video signal.
If you use the black coax say to the cable box and then from the cable box video output to the tv video input with the other cable, the cable box is demodulating the RF into video.
I guess the best answer is to go with what looks better for you. However, to give the RCA video connection a fair shake, perhaps you want to readjust the TV and see if there are other subtle differences you notice once the color is more to your liking.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #5 of 14 Old 03-29-2007, 10:29 AM
Quoted: 672 Post(s)
Liked: 456
It could certainly be that the video coax has a defined and correct impedance (75ohms) and the others do not.
Kal Rubinson
post #6 of 14 Old 04-29-2010, 02:00 PM
HomeAppraiser's Avatar
Same question three years later:
We just got a Dish VIP722k DVR with two satellite tuners and two outputs, one HD and one SD. I hooked the HD output to the first TV (a 1800p Plasma) with an HDMI cable and up my installer ran a dingle black coaxial cable to the second TV (a 540p CRT) in the bedroom. I am not happy with the SD picture sharpness on the CRT. Would a 25' run of RCA (Red Yellow White) provide a better picture?
HomeAppraiser is offline
post #7 of 14 Old 04-30-2010, 05:55 PM
Speedskater's Avatar
Quoted: 20 Post(s)
H.P. how do you select the Dish signal at the second TV (a 540p CRT) in the bedroom?
Do you tune to channel 3 or 4?
Or do you tune to "video" or "Aux" input?
Kevin
Speedskater is offline
post #8 of 14 Old 05-01-2010, 01:57 AM
Rammitinski's Avatar
You tune to a UHF channel - the default is channel 60, but you can change it (I think it starts at around channel 20 or so).
Yes, if you could run a long composite cable to the other TV, it would be an improvement (the RF coax run is Dish's standard installation method).
You can find extremely inexpensive, but very good, long lengths of composite cables at www.monoprice.com.
Rammitinski is offline
post #9 of 14 Old 05-01-2010, 02:26 AM
The bedroom TV is a Toshiba 30HF85 http://www.tacp.toshiba.com/televisi...p?model=30hf85 and the signal comes from a black coax cable directly into the TV. The installer said we need to select the Cable input and tune the TV to channel 73. The Dish VIP722k DVR box only has RCA and coax outputs for TV2.
post #10 of 14 Old 05-01-2010, 02:26 PM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
What you are referring to as RCA cable are also called composite cables.
HDMI Guy is offline
post #11 of 14 Old 05-01-2010, 04:10 PM
Quoted: 20 Post(s)
So before you spend any money on a long RCA (Composite Video) cable:
a) Drag the TV over to the Dish box and try it both ways with a short cable.
b) If you do use the RCA (Composite Video) cable, you will also so need audio cables!
Kevin
post #12 of 14 Old 05-01-2010, 10:33 PM
Composite cables = Red Yellow White
Component cables = Red Green Blue Video + Audio
The DVR box only has Composite cables or coax out for TV 2.
Also TV 2 is 110 pounds so I am not dragging it back into the living room anytime soon.
I found a some inexpensive cable at Monoprice to try out.
post #13 of 14 Old 05-01-2010, 10:58 PM
Yes, that's exactly what you need.
And no need to try anything first, either. It'll work.
post #14 of 14 Old 08-02-2010, 09:40 AM
ElizaScar's Avatar
Found this article at cableorganizer.com/articles/component-video-cables-demystified
They also sell a lot of products to help install and manage cables, with lots of helpful tutorials and tips
ElizaScar is offline
Reply Cable, Digital Cable - Non-HDTV
