Stand alone Tv Tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-04-2007, 03:27 PM - Thread Starter
crzyb1080's Avatar
I'm in the market for a projector and since i'm probably going to not have a cable box i'll need a stand alone tv tuner.
something like this:
http://www.digit-life.com/articles2/...k-tv-pro2.html
since i'll be hooking up my cd/dvd/xbox360 to a receiver, i'll just be watching tv on it. Tv doesn't have to be HD, but i don't want it to be insanely bad quality.
Any suggetions on what i should do? maybe just use a tuner in a vcr? i dunno Thanks!
crzyb1080 is offline
post #2 of 8 Old 04-04-2007, 03:49 PM
kenglish's Avatar
Liked: 39
Where are you located? That looks like an analog-only tuner, and it is for european standards as well.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #3 of 8 Old 04-04-2007, 04:18 PM - Thread Starter
crzyb1080's Avatar
Wisconsin/Minnesota (i go to school in Minnesota), and i didn't mean that exact item, just an example of what i'm looking for. Basically a tv tuner that has an output like s-video, composite, etc. to hook up to my projector.
Looking for suggestions of what to get. Thanks
post #4 of 8 Old 04-04-2007, 07:03 PM - Thread Starter
crzyb1080's Avatar
would this work? with decent quality on a projector?
http://aver.com/mpd/tvbox7.html
post #5 of 8 Old 04-05-2007, 05:25 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Are we talking OTA or basic cable?
RCbridge is offline
post #6 of 8 Old 04-05-2007, 08:11 AM
Noel Goodman's Avatar
My Sharp does a bad job of upscaling my cable -is there anything I can buy to clean up the image?
Noel Goodman is offline
post #7 of 8 Old 04-05-2007, 12:25 PM - Thread Starter
crzyb1080's Avatar
basic "extended" cable so theres no box involved... otherwise i would just use the output of that to the projector (which would make things alot easier but i'm in college and can't afford the extra $$ a month for digital) and i'm assuming that OTA means "off the antenna"
maybe i'll ask my roomies if they'd be down with upgrading to digital, either way any suggestions on what i can do?
post #8 of 8 Old 04-05-2007, 05:43 PM
Targus's Avatar
WHy not use the tuner in a VCR?
Targus is offline
Reply Cable, Digital Cable - Non-HDTV
