I tried to copy an ON DEMAND Comcast show and my VCR is messed up, what happened? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-10-2008, 06:55 PM - Thread Starter
alan892's Avatar
Hello. My problem may be too low tech for this forum, but I hoped that if you cannot comment directly perhaps you could suggest a different approach. I have Comcast digital cable and I use a (blush) VCR to tape some programs. I attempted to tape an ON DEMAND show. Of course the resulting tape was scrambled. Fine, but now ALL recording is scrambled. Even some tapes recorded long ago are unplayable. Comcast so far has been no help. Ideas? Thanks!
alan892 is offline
post #2 of 10 Old 02-10-2008, 07:44 PM
skiman24's Avatar
Well this can't be too hard of a problem to figure out this is not my expertise but I will gladly try to help out. First off is the setup, make sure the cable box is going into the vcr and the vcr is going to the tv. Recording make sure you select what line in input that you are recording and not the actual tv channel. I did this before and got snow for 2 hours. Of course that was back in the day before I had DVR. Plus the recorded show must be on that channel and the cable box must be on. Now that is if you are running composite or S-video. Now if you are using coax and have a vcr with vcr plus then you should be able to record the analog shows with no problem the digital shows will not work. If I was you I would just invest the each 5 bucks to get the cable box with DVR. Once you go DVR there is nothing else!!! I would be dead to the world if I didn't have a DVR now.
skiman24 is offline
post #3 of 10 Old 02-11-2008, 11:42 AM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
Did you change any connections?
Did you change settings on the VCR??
Give some more details and I will try to help.
HDMI Guy is offline
post #4 of 10 Old 02-13-2008, 04:03 AM - Thread Starter
alan892's Avatar
Thank you. No settings were changed, no connections were changed. Comcast must send a scrambling signal to the vcr, and it has not gone away.
alan892 is offline
post #5 of 10 Old 02-17-2008, 10:30 AM
trekguy's Avatar
Connect your VCR to another TV if you can (S-vid, composite or RF to channel 3) and try an old tape. If it is scrambled the likelyhood is that your VCR has failed.
AFIK Comcast has no ability to send a "scrambling" signal that would change your VCR.
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #6 of 10 Old 02-17-2008, 12:31 PM
homcom's Avatar
No such signal.
homcom is offline
post #7 of 10 Old 02-17-2008, 01:37 PM
ekaxel's Avatar
Aren't most of the On Demand programs copy protected? Also, they are all digital, and a VCR won't record digital programs. I am assuming the VCR is directly connected to the Comcast box somehow...
ekaxel is offline
post #8 of 10 Old 02-17-2008, 03:18 PM
homcom's Avatar
Through analog inputs a VCR will have no problem recording what is coming from a cable box.
homcom is offline
post #9 of 10 Old 02-17-2008, 05:08 PM
Desert Hawk's Avatar
Can't a cable company send Macrovision copy protection to prevent analog recording? If you left it recording a Macrovision encoded signal for 2 hours you might have fried the automatic gain control.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #10 of 10 Old 02-18-2008, 08:15 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
If you can't play a previously working tape on another TV, then you probably clogged the heads and the timing is incidental. (or the VCR just broke on it's own) The AGC in on the input only, not the output. (and it's actually taking advantage of poorly designed VHS electronics - Beta rarely had any problem with Macrovision due to it's superior video processing circuits)
While Macrovision has been seen on HBO and other analog premium channels, digital usually uses flags that newer VCRs (post year 2000) and recording devices detect and just stop recording. Since they have to pay for each use of Macrovision (licensed), it's use is not that common (as I understand it - no personal experience since my recorders don't recognise either protection method)
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
Reply Cable, Digital Cable - Non-HDTV
