Has anyone run low bandwith DVI-D 50 feet or more? - AVS Forum | Home Theater Discussions And Reviews
Old 12-26-2001, 11:26 PM - Thread Starter
colby's Avatar
I'm looking to run a single-link DVI-D signal about 50 feet from a HTPC to a plasma display. I'll probably be running the display at 1360x768@60Hz, which with a 5% blanking interval translates into a 65MHz pixel clock - well below the 165MHz single link DVI limit. I'm wondering if anyone has had success with using longer DVI cables for applications like this. The following company appears to be offering cables up to 75ft for just this type of application:
http://www.inlineinc.com/products/coax/pdf/IN9700.pdf
Has anyone done this successfully?
Colby
colby is offline
