wireless PC to HT connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-27-2008, 06:48 AM - Thread Starter
Digitude's Avatar
I would like to be able to remote my Itunes audio collection on my PC over to my home theater stereo system. My PC and HT are in different rooms though. Does anyone know of a wireless product that I could use to do this?
Digitude is offline
post #2 of 4 Old 07-27-2008, 07:08 AM
butthead's Avatar
Do you already have a WiFi network setup? If so, you might want to take a look at the Linksys Music Bridge. It basically shows up in your computer as another audio card, so it will work with Itunes or any other piece of software that will output audio on your computer.
butthead is offline
post #3 of 4 Old 07-30-2008, 01:13 PM - Thread Starter
Digitude's Avatar
Thanks. That looks like an interesting product. I don't have WiFi with my PC though.
Digitude is offline
post #4 of 4 Old 07-31-2008, 12:46 PM
crutschow's Avatar
Another product to consider is the Squeezebox (or Squeezebox Duet) http://www.slimdevices.com/pi_duet.html. I have the Duet and am happy with it. The Duet has a wireless remote with an Ipod type display that shows your available music (including album cover if available) and allows remote control anywhere in your house.
You can, of course, easily add a wireless router to you PC for a wireless connection.
Carl
Curmudgeon Elektroniker
crutschow is offline
Reply Home A/V Distribution
