HDMI cable with removeable connector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-21-2008, 09:41 AM - Thread Starter
semtex's Avatar
Friend of mine wants to run HDMI through some conduit, trouble is the conduit is too narrow. I remember reading about some HDMI cables with removeable connectors, can anyone point me in the right direction?
semtex is offline
post #2 of 4 Old 10-21-2008, 09:49 AM
jalis's Avatar
i dont know about HDMI connecters coming off the actual cable but you can try http://www.rapidrun.com/ or try a google search for HDMI over Fiber.
jalis is offline
post #3 of 4 Old 10-21-2008, 10:05 AM - Thread Starter
semtex's Avatar
thanks, ive used rapid run in the past with good results. will keep searching around, i am 99% ive seen what im after. go go bookmarks
semtex is offline
post #4 of 4 Old 10-21-2008, 02:51 PM
crutschow's Avatar
A removable HDMI connector would require another connector to connect to the wire. Don't think you will find that.
How big is the conduit? He might be able to shave the connector body enough to squeeze through.
Another option is to run two CAT-6 cables and use an HDMI to CAT-5/6 converter such as http://www.outdoorspeakerdepot.com/caexforhd.html or http://www.uniqueproductsonline.com/hdovcat5ecae.html.
Carl
Curmudgeon Elektroniker
crutschow is offline
Reply Home A/V Distribution
