New HD distribution via QAM tuners from Bocs? Cheap HD Modulation? - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 321 Old 09-09-2011, 05:17 AM
LI-SVT's Avatar
Use any Blu Ray player with the HDfurry to convert HDMI to component.
LI-SVT is offline
post #302 of 321 Old 09-24-2011, 06:07 PM
tbielowicz's Avatar
Quoted: 21 Post(s)
Does anyone know how to get the BOCs distribution signal on a TV utilizing a CableCARD? I have yet to find a way around this.
Family Room 7.1 setup: KS8000 / Energy RC Micro / Mirage BPS 150 / Pioneer SC-1323k
Home Theater 5.4.1 setup: Benq W1070 / SVS Prime Satellites / SVS SB12-NSD / Denon x4300h
tbielowicz is offline
post #303 of 321 Old 01-23-2013, 07:16 PM
jmanderson10's Avatar
So I know this product is pretty much dead but I am installing my old unit in a parent's house and can't seem to find my installation instructions/device code list. Unfortunately the website appears to be down and I was wondering if anyone out there happens to have saved the old .pdf files and could shoot them to me.
Thanks in advance.
jmanderson10 is offline
post #304 of 321 Old 01-23-2013, 07:43 PM
DGF
DGF's Avatar
Liked: 39
Thanks in advance.
I took a serious look at BOCS a few years ago, but unfortunately didn't archive any of the relevant literature. You're right about the web site being down, but BOCS did have some business ties to another company called Amperor (sales or marketing outfit???) ....and they still have a few of the BOCS docs posted:
http://www.amperordirect.com/pc/r-product-support/z-reference-bocs-mediahub.html
....they have many (dead) links to Bocsco.com, but there still are a couple of documents on the Amperor site that might give you some pointers, such as http://www.amperordirect.com/mm5/website_v3/products/bocs/BOCS%20Application%20Notebook.pdf .....but the real nugget may be that there are still several live links to YouTube vids, showing install details, that are still up and running.
So....not exactly what you were asking for, but maybe you'll find something usable.
It's a shame to hear about BOCS' demise - the "Head BOCS" dude, David, came across as a knowledgeable and stand-up guy - tough market, I guess!
Dave [no....no connection to BOCS' Dave!]
DGF is offline
post #305 of 321 Old 01-27-2013, 07:54 PM
Just wanted to say thanks. I had found the amperor direct website but not the videos. They had helped but I still needed codes. Luckily one of my kids showed me where he had "organized" the papers and I found them. Thanks again for the help. Too bad the HD version never materialized....it's a pretty cool product.
And if anyone stumbles across this and needs the documents just let me know.
post #306 of 321 Old 01-28-2013, 08:04 AM
DGF
DGF's Avatar
Liked: 39
You're wlecome. I figured you'd probably found the Amperor site, but posted the links just in case you hadn't.
Yup, the lack of HD capabilities did seem to be the final nail in the coffin - I know that there were difficulties with obtaining "HD chips" - shame, good product.
Dave
DGF is offline
post #307 of 321 Old 03-22-2013, 10:59 PM
Emilio Olavarri's Avatar
Dear Friend: I have 2 BOCS working perfectly for the last two years. if you go to bocsco.com you could find the manual and everithing to make an installation.
If you need any help, please let me know.
Emilio Olavarri is offline
post #308 of 321 Old 06-01-2013, 10:57 AM
baf01's Avatar
Can BOCS be used with Uverse STB's? Are there remote codes to match the AT&T remotes?
baf01 is offline
post #309 of 321 Old 01-02-2014, 10:56 AM
wileyNE3's Avatar
Does anyone have access to the PDF documents on the myxtender.com website?  I'm trying to set up a second xtender and need some additional info that can be found in the "Second BOCS.pdf" document, but I cannot find it anywhere.  specifically I'm trying to figure out how to pair the remote to a second BOCS.
wileyNE3 is offline
post #310 of 321 Old 01-15-2014, 09:43 PM
tstuckart's Avatar
I have the "Second BOCS Install" PDF.
Programming:
Once you have things wired up (and double checked to make sure that two DC
power feeds are not using the same wire), you need to program your system to
use alternate channels as well as how to recognize both BOCS systems.
The shift button is critical in all these efforts – any programming sequence can be
directed at the second BOCS unit by simply pressing and releasing the shift
button (yellow up arrow) on the remote prior to entering a programming
sequence. For instance, to pair a remote with a BOCS device, you hit the pair
button on the front of a BOCS unit (all three lights will begin to flash), and within
15 seconds you press and hold “Menu” and “CH+” on a BOCS remote. The
remote will flash 3 times indicating a successful pairing. Now when you press a
red, green, or blue button on the BOCS remote, the corresponding color light on
the front of the BOCS unit will blink.
To pair a remote (the same remote) to a second BOCS unit, you press the pair
button on the front of the second BOCS unit then press shift then hold down
“Menu” and “CH+” on the BOCS remote. The power light should blink 3 times on
the second BOCS unit indicating success.
Now if you press “RED”, the red light on the first BOCS unit should flash and if
you press “SHIFT” then “RED”, the red light on the second BOCS unit should
flash. Note that few people get the binding to work right the first time – usually
accidentally binding the normal and shifted on the remote to the same unit. The
key is pressing shift then pressing “MENU” and “CH+” at EXACTLY the same
time.
Now if you are trying to program the IR code for the Red channel on the second
BOCS you press “SHIFT”, then hold down “RED” and “INFO” at the same time
(likewise for any other command)
We recommend leaving the first BOCS unit on the default channels and changing
only the channels on the second BOCS. If you are putting it on 76, 78, and 80,
then you would: Press shift, then press and hold “RED” and “CH-“ until the
power light comes on then enter the channels all together three digits each
“076078080” and press “OK”. The power light will blink twice to indicate
success. If you have the correct code programmed into the “LOCAL-TV” button
for the TV you are in front of, pressing “RED” should change the TV to 14 and
pressing “SHIFT” then “RED” should change the TV to 76.
Repeaters:
If you are using two BOCS units, a repeater must be bound to both of them. The
process is identical but you have to do it for each BOCS unit. Press the “PAIR”
button on the front of the BOCS unit then plug the repeater into
a wall outlet within 20 feet of the BOCS unit. Wait for the BOCS lights to stop
flashing (approximately 10 seconds) and unplug the repeater from the wall. Then
you can bind to the second BOCS unit in the same manner and then move the
repeater to the desired location to cover the extended area.
tstuckart is offline
post #311 of 321 Old 05-06-2014, 08:43 AM
mcf57's Avatar
I as looking into something using this product, but is this company still in business or are they pretty much dead? I haven't see ANY updates on the website (in maybe years) so I am thinking any kind of HD distribution equipment from them (like they state on the site) is a moot point & not going to happen.
mcf57 is offline
post #312 of 321 Old 05-06-2014, 09:36 AM
jautor's Avatar
Quoted: 1327 Post(s)
Liked: 850
Yep, have to assume it's a dead project... HD distribution is becoming less useful for most folks, as the combination of "whole house DVR" and inexpensive streaming devices have made major strides and provide more functionality with none of the hassles of distributed video.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #313 of 321 Old 10-14-2014, 06:33 AM
So I know that this product is dead in the water. It seems like it could still be used for a pretty robust 2-way IR/RF remote system. I have run into some road blocks with the newer XMP IR protocol and I'm hoping that someone stashed the remote information from this thread. I'm just trying to find ANY remote adapter or programming (not learning) information.
Thanks and sorry if you see similar posts at coccoontech, remote central, jp-1 forums. I'm really digging!
post #314 of 321 Old 11-03-2014, 09:54 AM
tstuckart's Avatar
jmanderson10 can you be more specific regarding what you need? I have several pieces of the BOCS documents in PDF form but they are too large to attach here.
post #315 of 321 Old 11-03-2014, 03:58 PM
I sure can. I have all the basic documentation. I am looking for the stuff in this thread.
BOCS 2way remote is now open source
This seems like it could be awesome but David and the user that was doing some of the programming (cragte) seem to have disappeared off the board.
post #316 of 321 Old 11-04-2014, 06:42 PM
tstuckart's Avatar
Ah, I see. I did have a remote upgraded by Craig Temple (cragte). At the time he was using an email of remoteupdate@live.com. I also have a mailing address for him from early 2010.
post #317 of 321 Old 11-04-2014, 06:46 PM
tstuckart's Avatar
Tried to PM you Craig's mailing address from 2010 but my post count is a couple to low to allow me to PM.
post #318 of 321 Old 11-04-2014, 06:53 PM
tstuckart's Avatar
OK, bumped myself over the needed count of posts. You should have a PM.
post #319 of 321 Old 11-05-2014, 02:56 PM
Thank you so much. I sent an email to that address and didn't hear anything back.
I'll have to think about sending him a letter. That seems a little stalker-y .....but you never know.
Again thanks. I really want to see what I can do with this bad boy.
post #320 of 321 Old 11-07-2014, 05:05 PM
tstuckart's Avatar
Well, report back if you get anywhere. I'd be interested to hear. Its a dead product so I don't expect much traffic on the threads anymore. I think they were just a little too late to market to get enough traction before it was common to have more than 1 HDTV in most homes and before the anyroom DVRs came out. I have 2-base units, 2 repeaters, and 5 or 6 remotes and I don't really use them since my system is HD and all digital now. I have thought about just using them for the RF as IR repeaters but that seems like overkill. Of course, having upgraded remotes helps. I should have had Craig upgrade more than 1 for me.
post #321 of 321 Old 11-28-2014, 05:27 AM
andy_hd's Avatar
I've been using the BOCs as an RF/IR remote controller for about 2 years (using 4 remotes upgraded by Craig). Works really well as it is a good combination of simplicity and functionality. Cheap too at $50/remote. I have 3 sources and 4 TVs controlled by a 4x4 matrix switch. The macro capability allows the red/green/blue buttons to both control the matrix as well as select the correct input for the local TV. As BOCs naturally supports 3 sources, but the matrix really constitutes a 4th source, Craig's macro mechanism allows me to steal unused codes from one of the supported sources to control it.
My family is totally dependent on this system. I wish I had bought more remotes from Craig in case one goes -- but I haven't gotten any responses from him recently.
If you do find a 'macro-capable' remote, I can help you with programming the macros.
andy_hd is offline
Reply Home A/V Distribution
