Adding a slingbox channel to my existing coax (with basic cable service) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 11-07-2008, 09:06 AM - Thread Starter
vwtoys's Avatar
Hi, I'm installing a Slingbox in a remote location and was wondering what's the best way to bring that video into the whole house. I currently have a PC with A/V out, and I'm using basic cable (no cable box, no internet through this service) and all the rooms are currently connected with the basic cable service. I've been reading about the use of a modulator to inject an extra channel into my existing coax cable. How should this be done? I'm wondering if I could just use the Channel Plus 55x5 series modulator and run the coax output of this unit to a combiner (two way splitter used to combine the signal) that would combine my Slingbox video feed (Let's say Channel 103, an empty channel in my cable service)? At what junction point do I put in this combiner? Do I have to run a new coax run from the room where the PC/Modulator is to the main splitter (is that called a drop?). Or can I just run the coax into the existing coax with a combiner in the same room and call it a day? (I'm thinking it couldn't be this easy.) Also if I inject this signal with just a combiner, would my neighbors see the same channel? How do I block it so the new channel only shows up in my house? I'm trying to do this with very little money.
Sorry for all the newbie questions. Any help is appreciated.
vwtoys is offline
post #2 of 20 Old 11-07-2008, 02:55 PM
crutschow's Avatar
A modulator will only work with SD signals, not with HD. Do you plan on sending any HD?
Carl
Curmudgeon Elektroniker
crutschow is offline
post #3 of 20 Old 11-07-2008, 08:36 PM - Thread Starter
vwtoys's Avatar
I am planning to add the slingbox channel as a SD channel. The a/v out of the computer is only rated for regular TV out. The slingbox content will be sent to the TV out (composite) and I'm trying to use the modulator to add that SD channel to my existing cable TV coax, so all the TVs in the house can see the same.
With the use of the modulator, the regular unscrambled HD channels from my cable service will still come through, right? (I don't see why it wouldn't.)
Can anyone tell me where I can wire this modulator in? And what about blocking the neighbors from seeing the modulated slingbox channel?
vwtoys is offline
post #4 of 20 Old 11-07-2008, 09:45 PM
Sokoloff's Avatar
You can use a low-pass-filter on your incoming coax feed to block all frequencies above a certain channel (LPF-450 will block everything above cable 62 for example) and combine your modulated channel(s) above that with a simple splitter wired in reverse.
The LPF will also serve to block the neighbor's access to your in-house channel. They're $40 new, but I just got one (an LPF-650) on Ebay for less than half of that.
Sokoloff is offline
post #5 of 20 Old 11-08-2008, 11:01 AM - Thread Starter
vwtoys's Avatar
If I connect the LPF at the drop, that essentially blocks information from channel 62 and up to get into(from cable company) or out of (from my modulator) my house? It works both ways?
So if I use a combiner (splitter) to inject the extra channel anywhere in the house the signal will be available on all coax around the house, right? This would save me the trouble of trying to run a coax to the drop from the room where the PC/modulator would be, which is about a 50 feet run.
vwtoys is offline
post #6 of 20 Old 11-08-2008, 11:15 AM - Thread Starter
vwtoys's Avatar
Manufacturer:
Channel Plus
Manufacturer Product No.: LPF-750
Passes: CATV 2-116
Off-air 2-60
Blocks: CATV >121
Off-air 65-69
So I see that I don't have any channels that I need/like above Ch120. But I do like the digital channels on 118. This says it passes 2-116, abd blocks 121 and up. What about the digital channels on 117-120? Are those going to be unwatchable?
vwtoys is offline
post #7 of 20 Old 11-08-2008, 11:26 AM
Sokoloff's Avatar
To your first question: yes, it blocks in both directions, so it will work like you want.
To your second question: be aware (it sounds like you might already be) that what your cable box "says" is digital channel 118 might not be channel 118 in terms of frequencies. If you know that the carrier is on channel 118 (your cable box diagnostics or tuner card might call it "118.1" "118.2", etc) then it will be partially attenuated by the filter (and 120 will be worse than 119, worse than 118, etc). My gut feeling is that 117 might work and 118 and above probably wouldn't, but it's so situationally dependent that it's impossible to say. (What signal strength your cable co is putting out, the cabling in your house, the sensitivity of the tuner you're using, etc.)
Sokoloff is offline
post #8 of 20 Old 11-08-2008, 04:02 PM - Thread Starter
vwtoys's Avatar
Thanks for all the replies thus far!
I'm only using my samsung lcd to tune into the digital channels. There's 118-39, 118-40 etc. Does that mean the digital channels are embedded in Ch 118? I'm not so sure myself. I might be able to live with that since there's an analog versions of 118 channels within the ch 2-99. So I'd still be alright.
So the last part of this mystery is: do you guys agree that I could inject the Channel Plus signal anywhere in the house with a combiner where there is a cable run? And the LPF will isolate the new slingbox channel, ch 123 (for example) within my house cabling, right?
vwtoys is offline
post #9 of 20 Old 11-10-2008, 07:10 AM
Sokoloff's Avatar
LPF will definitely isolate your house channel to your house.
You can inject the house channel anywhere in your house, but it will only be usably viewable to the entire house if you do it before the splitter(s). I have all my equipment centrally located, filter the incoming coax and inject my house channels there and only once all that's done, run it through a powered splitter to feed the house. I'm pretty sure you couldn't inject at the family room TV and expect to see that channel (at a usable signal level) on a bedroom TV.
As for your 118 question, if you have a agile modulator, just set it to 118, combine it onto your cable feed and see if the digital cable channels you suspect are on 118 are still clear. If they are, they aren't on 118.
Sokoloff is offline
post #10 of 20 Old 05-16-2009, 10:44 AM
atalow's Avatar
Can someone break down what was described above into utter lamen terms?
I'm wanting to do basically the same thing... add a composite channel to all the tvs in my house... so each tv could go to channel 80 (or whatever) and see what was on that dvd player. I have access to my cable source (before it gets split) and i have the 3 rca cables from the dvd player...
There are three parts I wasn't quite clear on:
1) What type of unit do I need to buy that would add the composite channel to the coax without messing up what's already coming in on the coax? This is the big question... I can't figure out what to search for or how much I should expect to pay.
2) I also receive internet and digital cable through the coax... is there a way to do this without messing up those things?
3) What's the purpose of the low pass filter and what specs would I need if I were buying one?
atalow is offline
post #11 of 20 Old 05-16-2009, 11:10 AM
Sokoloff's Avatar
1. Modulator will take the "red/white/yellow" composite video and audio and turn it into a cable channel. You specifically want a "frequency agile" modulator (that means "you can pick the channel it uses"). Channel Plus makes a whole line of them; I use the 5545 and SVM-24. Each can do 4 channels and do IR control. There's a 5525 that does 2, and many other models to choose from.
Then, you need a device to combine two coax feeds, one from that unit and one from the cable company. I use the Channel Plus 8200 for that, which also provides power to the IR targets and relays the IR commands back to the modulator.
At each TV, I have 2133 targets (to hit with the remote controls for the DVD player in your case). The signal comes from the remote and hits the 2133. That puts it on the coax and sends it back to the 8200, which sends it to the modulator, which has IR emitters attached to control the DVD player.
Channel plus sells this all in a kit, the numbers of which I'm a little too time-pressed to look up, but some quick googling on your part should turn it up.
2. As long as you stick to high channels, you won't interfere with the cable modem, though you'll need to get the 8200-BID (bi-directional) to support a cable modem. Instead, I moved my cable modem to the basement cable entry and it's before all the video stuff.
Digital cable will cause a conflict if you pick the same channel that the cable company is using for their digital signal. (Note that the channels you see on the cable box, 852, 354, etc, aren't the actual channels on the coax; they're just a convenience for you.)
3. THe low pass filter is to block all the channels on the cable company feed to "clear out" some channels for you to use in the house. I knock out channels 69 and above (something approximately like that anyway), and I use the high number channels for my house channels. That does mean that a digital cable box won't work in the main part of my house, so if I had one, I'd have to put it in the basement and treat it like you're going to use the DVD player. (Put its output on a house channel, and cable its coax feed up before the low-pass filter.) That would also preclude getting many HD channels in HD, as the modulation is entirely SD NTSC.
If your cable company isn't using channel 79, 80 or 81 for their signal, you probably won't need the LPF and you can just get channel 80 overlaid onto your feed no problem. If they are, you'll need to find a spot where there's 3 channels in a row not in use, or you'll need to use filters.
Sokoloff is offline
post #12 of 20 Old 05-16-2009, 11:37 AM
atalow's Avatar
Fantastic response. Thanks so much for your help... I'll give it a shot.
atalow is offline
post #13 of 20 Old 08-31-2009, 08:24 AM
GregStarling's Avatar
Adding a question to this really good discussion.
If I want the signal being bounced around the house from a single source to be HD quality, is there specific type of equipment I should buy? Is it even possible to "forward" a 1080p signal (or any high def for that matter) using this method?
GregStarling is offline
post #14 of 20 Old 08-31-2009, 03:37 PM
crutschow's Avatar
By "bounced around" do you mean wirelessly or wired?
There are "soon to be released" options for wireless and available options for wired.
Carl
post #15 of 20 Old 08-31-2009, 03:41 PM
I mean wired. I have no issues running wires, I just want to make sure that I get a good 1080 signal to every tv that is sharing the signal.
post #16 of 20 Old 08-31-2009, 04:08 PM
S-dogg's Avatar
Referring to modulators, I'm not aware of any ATSC/QAM modulators on the market. There's been some announcements, but they've all been vaporware so far. If anyone knows of any actual hardware, I think we'd all like to hear about it.
On a side note, does anyone have any experience using a channel modulator with Fios? I'll be moving to a Fios area soon, and I'm not sure about my options here.
Insanity is just a state of mind
Visit the Atomic Playground for the latest on movies, video games, computers, and more!
http://atomic-playground.blogspot.com
S-dogg is offline
post #17 of 20 Old 09-01-2009, 11:04 PM
post #18 of 20 Old 10-06-2009, 11:47 AM - Thread Starter
vwtoys's Avatar
It's been a while since I looked at my post. I thought I'd chime in again. I went ahead and got a modulator, but now it's for a different purpose. It's for my surveillance camera setup and it's supposed to add whole house access to the surveillance feed. I have tried to use a regular splitter flipped around to combine the cable TV/Surveillance feed together, currently without a LPF low-pass filter. When I do that I get all kinds of interference and cannot see any picture from either the cable side or the surveillance side. I tried a different splitter (flipped) and it didn't work either. I placed the channel where there's a considerable gap of empty channels(83-95 are not occupied with an analog feed) Is there some magic in the Channel Plus brand "combiner" that these regular splitters can't do? Do I have to buy one of those? Does the Low-pass filters do anything to remedy this problem? (It is on my to-buy list, I just haven't figured out what else I need yet) Currently the surveillance system is fed to a remote tv using the channel plus modulator as a standalone system and it works fine.
vwtoys is offline
post #19 of 20 Old 10-06-2009, 03:27 PM
David Feller's Avatar
A few things here:
1) There is a QAM modulator currently on the market from a company called Zeevee.com - they run about $1000 for a single channel, are frequency agile, and must be filtered/combined like any "off the shelf modulator" - Other options are coming but this is the only "reasonably priced one" currently on the market.
2) As for modulation, there is a lot of info on this post, but the biggest recurring issue is loss of (either through interference or filtering out) valuable CATV channels. Unless a household is PURELY analog (meaning no set top boxes of any kind, no cable modem, no VOIP, and no reception of digital channels with a digital tuner built into a TV) then any standard way to filter out channels and insert your own will will result in loss of something. (That includes channel notch filters, low pass filtering etc.)
So far, the only way folks have avoided that loss has been to use frequencies around 100Mhz (specifically because that is where FM stations are located and most cable companies tend to avoid using those frequencies) - BUT the problem is that off the shelf modulators cannot use those frequencies due to sidebands they create. They end up knocking out 20 or 30 channels if you force them to those frequencies. (If you are really interested feel free to look at this little presentation)
Before you read on, a little caveat, I am associated with the company that makes the following product and am therefore biased - so research it for yourself (see the BOCS thread in this same forum)...
The BOCS product can take up to three inputs and distribute them home-wide using the FM band AND can both transmit and receive on the same coax wire (no need to put the modulator at the demarc point - put it anywhere in the home even with a single wire), it does not interfere with analog or digital cable, AND it includes the full wireless remote control system spoken of above. It also includes all the filtering so your neighbors cannot see the stream. The nice extra is that beyond a sling or security camera you can plug two other things in - the most common is a DVR - watch those recorded shows from anywhere else in the home. Lots more detailed info on the website www.bocsco.com
David Feller
David Feller is offline
post #20 of 20 Old 10-06-2009, 03:29 PM
Sorry, I missed responding to this - the reason you are having trouble is that whatever channel you put your modulator on - even if you tune your TV to that same channel to see if anything is there - is occupied by either analog or digital signals. You MUST filter. Low pass are the easiest but obviously known out the most. There are lots available and you can get them from solidsignal and many other places online.
David
Reply Home A/V Distribution
