QAM Channels - Frequencies? - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2008, 01:14 PM - Thread Starter
jimre's Avatar
Quick question on digital cable QAM systems. When looking at the underlying major/minor channels numbers (say, as reported by Silicon Dust's web site) - do the major channel numbers map to the same frequencies as analog cable channel numbers? If my cable system delivers digital content on channels 87.1 and 87.2 - are those two logical channels using the same carrier frequency as analog cable channel 87 (600-606Mhz)?
Or does QAM use some other channel/frequency mapping convention? Thanks...
jimre is offline
Old 11-09-2008, 01:19 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Originally Posted by jimre View Post
Quick question on digital cable QAM systems. When looking at the underlying major/minor channels numbers (say, as reported by Silicon Dust's web site) - do the major channel numbers map to the same frequencies as analog cable channel numbers? If my cable system delivers digital content on channels 87.1 and 87.2 - are those two logical channels using the same carrier frequency as analog cable channel 87 (600-606Mhz)?Thanks...
Yes. The number before the "." is the NTSC channel number.
CIAO!
Ed N.
egnlsn is offline
