Elan Z630 - how does the remote work? - AVS Forum | Home Theater Discussions And Reviews
Old 12-12-2008, 10:17 PM - Thread Starter
ecloud's Avatar
I just got one of these on Ebay. It came with a remote, but nothing else. I'm beginning to wonder if there is actually an IR receiver on the front panel, because the remote doesn't seem to control it. (I can see that the remote is putting out a signal though - it makes the LED blink on my Powermid receiver.) Is it necessary to connect an IR receiver module to the Z630 for it to receive commands?
Otherwise can somebody give me a clue about the buttons, if there is some magic sequence that makes it switch inputs, switch zones, control the volume etc.?
ecloud is offline
Old 12-16-2008, 04:10 PM
Greg C's Avatar
There is no IR receiver on the 630. You need to hardwire ir to the box.
Greg C.
www.pghcustomht.com
CEDIA University Designer CAT Member
CEDIA University Instructor
Crestron DMC-E
Greg C is offline
