RCA A/B toggle switch need HELP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-27-2008, 06:29 AM - Thread Starter
chobo's Avatar
I am looking for an RCA/composite cable switch. It needs one input and two outputs and the toggle switch also. I have searched the internet but have not found one. Is there such a product even made?
Please provide link to one also, if possible.
chobo is offline
post #2 of 13 Old 12-27-2008, 07:02 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Any old A/V switch would do (also called Video Selector). Here is one. You can also get them at Rat Shack, Wally World, Circuit City, Best Buy, etc.
CIAO!
Ed N.
egnlsn is offline
post #3 of 13 Old 12-27-2008, 07:07 AM
Duct Tape's Avatar
a switch would have multiple inputs and 1 output. these are pretty common.
what is it that you are trying to accomplish?
is ther any reason why this wouldnt work?
http://www.radioshack.com/product/in...odsInSession=1
egnlsn beat me to it
Duct Tape is offline
post #4 of 13 Old 12-27-2008, 08:34 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
And early in the morning, too.
CIAO!
Ed N.
egnlsn is offline
post #5 of 13 Old 12-27-2008, 06:40 PM - Thread Starter
chobo's Avatar
I am going to have video out from my DirecTV box into the switch via RCA cables. Then the switch will output into my VCR and also into a Wireless Video Transmitter (X10), both via RCA. My plan was to have a toggle switch so that I can switch between either the VCR or Wireless Video Transmitter.
Will this work?
Forgot to mention I cannot find a 1-in 2-out video selector for Composite/RCA cables. That is what I am looking for.
chobo is offline
post #6 of 13 Old 12-27-2008, 07:00 PM
Duct Tape's Avatar
you dont need a selector, you need a video distribution amplifier. this way you can have the signal going to both devices at the same time without signal degradation.
http://www.smarthome.com/8141/4-Way-...e-Video/p.aspx
which directv box do you have?
post #7 of 13 Old 12-27-2008, 07:24 PM - Thread Starter
chobo's Avatar
I'm not exactly sure, but I believe it is the base model D10.
chobo is offline
post #8 of 13 Old 12-27-2008, 08:11 PM
Duct Tape's Avatar
nevermind then, i was just going to say that you wouldnt need additional parts if you had the H20/21. those have enough composite outputs, along with component and HDMI to do what you want to do. maybe it is time to upgrade to HD?
post #9 of 13 Old 12-27-2008, 09:08 PM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
The D10s have 2 sets of composite outputs.
CIAO!
Ed N.
egnlsn is offline
post #10 of 13 Old 12-28-2008, 06:06 AM
Duct Tape's Avatar
yeah, but he may be going directly to a television with the first set, and wants to split the 2nd set.
of course, he could just wire the first set through the vcr, then back to his tv. and just make sure the vcr is on and set the line input when watching DTV.
or he could step into the 21st century and buy a HR21 and throw the vcr away
post #11 of 13 Old 12-28-2008, 06:48 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
yeah, but he may be going directly to a television with the first set, and wants to split the 2nd set. :confused
If that's the case, then, yeah, an A/V distribution amp such as a CT-400 would be needed.
CIAO!
Ed N.
egnlsn is offline
post #12 of 13 Old 12-28-2008, 10:08 AM - Thread Starter
chobo's Avatar
I'm not sure if this will work. Could I just use this 2-way video selector, but use it in the reverse? By having the one output as my input and then the two inputs as my two outputs? ( http://www.radioshack.com/product/in...44&tab=summary ) I then could toggle between which ever device I need to send audio/video to. Please advise.
chobo is offline
post #13 of 13 Old 12-28-2008, 12:08 PM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
That's exactly what was suggested earlier. It would do fine.
CIAO!
Ed N.
egnlsn is offline
Reply Home A/V Distribution
