VGA to M1 via DVI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-22-2009, 03:02 PM - Thread Starter
pedromt's Avatar
I need to figure out how to get a signal from a VGA source (PC) via a DVI-D cable to an M1 source (Projector).
The reason for this is I want to run a DVI cable through the wall to allow for either a HDMI, DVI, or VGA input. I was hoping to be able to accomplish this through the use of adapters. Currently as it is the HDMI signal will go through, but not the VGA. I wasn't aware of how many different kinds of DVI connections existed until recently, so I've identified the cable in the wall as a DVI-D. I could replace it with a different kind of DVI cable if I need one that will do analog as well as video but right now I'm kind of on information overload and am having a hard time figuring out exactly what I need.
pedromt is offline
post #2 of 7 Old 01-22-2009, 03:09 PM - Thread Starter
pedromt's Avatar
or... would it just be easier to go M1 to HDMI and then from HDMI go to VGA or DVI as needed?
If so, I could then just run HDMI through the wall and have the appropriate HDMI to DVI or HDMI to VGA cables for the input.
pedromt is offline
post #3 of 7 Old 01-22-2009, 03:34 PM
cavu's Avatar
Can't do it. VGA is analog. A DVI-D cable is purely digital.
You need a DVI-A (analog) or DVI-I (analog & digital) cable.
Call monoprice.com and ask them for advice as to which cable to use.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #4 of 7 Old 01-22-2009, 03:45 PM - Thread Starter
pedromt's Avatar
cavu,
thanks. That's the conclusion I was getting at as well... so the question now is: can I go M1 to DVI-I to VGA?
any idea why all the DVI-I cables on monoprice are only male-male?
I'm starting to like the idea of just using HDMI in the wall more and more, though.
pedromt is offline
post #5 of 7 Old 01-22-2009, 06:59 PM
cavu's Avatar
Certainly, with the right adapters.
All regular cables are male-to-male. A female to male is considered an 'extension' cable.
In fact, you are probably better off to run an M1-DA extension cable from end to end as it will have all the necessary conductors included.
" - MLK
cavu is offline
post #6 of 7 Old 01-23-2009, 09:40 AM - Thread Starter
pedromt's Avatar
any idea where to find an M1 D&A cable?
pedromt is offline
post #7 of 7 Old 01-23-2009, 10:13 AM
cavu's Avatar
blackbox.com sells them for ~$25 for a 25ft. You may have to phone them for the M1-DA male->female version.
" - MLK
cavu is offline
Reply Home A/V Distribution
