Noobish Cabling Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-26-2009, 07:59 AM - Thread Starter
RhythmAddict's Avatar
Hey guys,
Quick-ish question here....I am setting up my apartment with some cabling since we're doing construction. We have cable source coming in that is being split two-ways. The previous owners had 1 cable modem, and one TV. However, I need 2 TVs and one cable modem. Is this going to be as easy as getting a 1 to 3 way splitter, do I need to do something else? I've seen talk of modulators and amp levels on other threads...however I really need some help figuring out exactly what I need....someone please point me in the right direction!
RhythmAddict is offline
post #2 of 5 Old 01-26-2009, 08:17 AM
Neurorad's Avatar
Quoted: 71 Post(s)
Liked: 99
Depends on how long the cable runs are.
Buy 2 2-way splitters, to preserve more signal to the modem.
In an apartment, I doubt you'll need an amplifier, but somebody else with more experience may chime in.
Run additional cables now, if you have the chance. Ethernet to wall light switch locations? All potential TV areas? Stereo? Have you considered in-wall or in-ceiling speakers for distributed audio? Hardwired alarm system? 5.1 or 7.1 surround for the TV area?
How long will you stay in that apt?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #3 of 5 Old 01-26-2009, 08:52 AM - Thread Starter
The coax cables will be 50 feet each, each going to a TV.
Currently, the cable comes in and is split in a closet. I'm going to hook in the cable modem from inside the closet where my networking gear will be (2 cisco 2620 routers, 1 Cisco 24 port catalyst switch). I'll cat6 Ethernet out of the closet, so the coax from cable source to the actual cable modem will probably be less than 3 FT at most.
The longer coax cables will only be going to cable boxes (I am _assuming_ these require less juice than the cable modem...?)
The Ethernet will be running to my office and to behind the TV
Great idea on the speaker-wires, I'm not sure how the heck I didn't think of that! I used to have in-wall speakers in my old place, I actually prefer having speakers that are somewhat less permanent though
If anyone else has any other thoughts, suggestions, or things to remind me of I am all ears...errr...eyes
post #4 of 5 Old 01-26-2009, 10:57 AM
jimre's Avatar
Good resource to help figure out cable wiring requirements:
http://www.swhowto.com/VideoLoss.htm
jimre is offline
post #5 of 5 Old 01-28-2009, 02:48 PM - Thread Starter
All,
Thanks for your help!
Reply Home A/V Distribution
