2nd modem for internet radio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-16-2009, 08:43 PM - Thread Starter
Baddad1's Avatar
I have a DSL modem that is a long way from my receiver. Due to the house layout, pulling cat 5 to the receiver would be a nightmare. Can I p/u a 2nd modem and hook it to a phone jack by the receiver? If so, what would I need to do to make it work?
Sorry for the vague questions, but I'm not at all experienced with internet hookup options. Thanks, Bob
Baddad1 is offline
post #2 of 8 Old 03-16-2009, 08:48 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You need a wireless bridge device, in addition to a wireless network.
http://www.techweb.com/encyclopedia/...=Wi%2DFibridge
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 8 Old 03-17-2009, 07:02 AM
tmnjus's Avatar
Or ethernet powerline adapters, such as this.
Best is what you perceive it to be, not what others tell you it is.
tmnjus is offline
post #4 of 8 Old 03-17-2009, 08:41 AM
McSmarty's Avatar
Just get a Squeezebox or Sonos and hook into your receiver. It will play internet radio from wireless internet. Also it plays your mp3 connection.
McSmarty is offline
post #5 of 8 Old 03-17-2009, 12:25 PM
localnet's Avatar
I would go the above route. Probably the cheapest solution, and they work.
Or you may be able to use an Apple Airport Express. I have two of them hooked into my whole house audio system and those work very well too. http://store.apple.com/us/product/MB...mco=MjE0NDc0OQ
localnet is offline
post #6 of 8 Old 03-17-2009, 07:17 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I read about x10 and UPB, and I wonder why Nuvo, Russound, and other high-end manufacturers would ever consider releasing something using PLC. I think they're smoking crack.
There are just too many problems using PLC.
Neurorad is offline
post #7 of 8 Old 03-20-2009, 03:57 PM - Thread Starter
Baddad1's Avatar
Thanks for the ideas. Bob
Baddad1 is offline
post #8 of 8 Old 03-25-2009, 09:15 AM
LuncHwagon's Avatar
And to specifically answer your question. Two modems on the same copper pair will NOT work. In fact, adding another modem will cause BOTH modems to stop working properly. One at a time.
LuncHwagon is offline
Reply Home A/V Distribution
