Exterior CAT5 - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2009, 12:19 PM - Thread Starter
Will-san's Avatar
I need to run a hard ethernet line to my home office. There is no workable path inside the house. Can anyone recommend a vendor for outdoor rated Cat5?
"I was just reading here on my internet that Tofu is made from little baby seals". - Strong Bad
Will-san is offline
Old 03-28-2009, 06:13 PM
AceCannon's Avatar
You could run conduit, then any sort of cat5e.
AceCannon is offline
Old 03-29-2009, 07:08 PM - Thread Starter
Will-san's Avatar
yeah I considered that but too many twists and turns. I just want to tie wrap to an existing coax run.
Will-san is offline
Old 03-30-2009, 08:32 AM
fedders's Avatar
You can use something rated CMX-outdoor (includes a cold-bend test and 720 hour UV) for this application, but you will want to tuck it up under the siding or hide it any other way you can to reduce exposure to UV.
Carl
Carl Fedders
fedders is offline
Old 04-01-2009, 11:08 AM
HiFiHomeTheater's Avatar
Check out sewelldirect.com. They have very good prices on bulk cable, and if you call them up they are willing to work with you and get you exactly what you need. They are super fast shippers too.
HiFiHomeTheater is offline
