Best option to convert exising RG6 run to HD - AVS Forum | Home Theater Discussions And Reviews
Old 03-29-2009, 01:58 PM - Thread Starter
Double Eagle's Avatar
I have been searching and reading posts for the last hour to figure out the best solution for my problem. I am sure this has been discussed here many times in the past but I couldn't find anything specific to my issue.
I have a friend who has a plasma wall-mounted TV that he spent a bunch of money on a few years ago to have built into a picture frame mount in his wall. It uses an articulating mount so rear access is no problem. However, the only video feed he has is a single RG6 cable in the wall running from his cable box which is remote mounted in a cabitnet. Because of this he has been watching SD video on his expensive plasma. He has asked me to help him and I want to confirm the best option to solve the problem.
He bought his plasma several years ago and it only has component video, no HDMI. As I understand it, he will need to either pull 2 cat5 cables from from the cable box or pull 5 RG6 cables. While it is likely 2 cat5 cables could be pulled using the old RG6, pulling 5 new RG6 cables might be a problem if the existing holes for the cable feed are be large enough.
So, would using 2 cat5 cables with component baluns be best or are there other options I have missed?
Double Eagle is offline
Old 03-29-2009, 03:52 PM
Wayne A. Pflughaupt's Avatar
Quoted: 100 Post(s)
Liked: 69
Five RG-6 for component video, which only uses three cables?
Since video signals only require a 75-ohm cable, three RG-59 would do the job. It's thinner than RG-6 so it might better fit your physical limitations. If not, try a bundled multi cable like Canare V3-3C. You'd have to get a professional to come out and crimp on the RCA ends, though, or buy the tools to do it yourself.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
Old 03-29-2009, 03:57 PM
drew300's Avatar
http://www.gefen.com/kvm/dproduct.jsp?prod_id=5303
He can buy this expensive piece to go with his expensive plasma. Not out yet but will help out with tough situations like yours.
drew300 is offline
Old 03-29-2009, 04:57 PM
Quoted: 100 Post(s)
Liked: 69
If I'm reading it right, it uses HDMI on both ends. His TV doesn't have HDMI.
Wayne A. Pflughaupt
Equipment List
Old 03-29-2009, 06:06 PM
eelton's Avatar
I assume the extra two are for stereo audio.
If you can use digital audio, you can send that with component video over one cat5 cable. If you need analog audio, then two cat5 cables would be needed.
Edit: I hadn't seen this before, but it looks like this unit does component plus analog audio over a single cat5 cable.
--Eric
eelton is offline
Old 04-02-2009, 06:01 PM
gmiles's Avatar
I too have searched for something similar.. I bought 4 new lcd panels for my daughters rooms... I'd love to find a cheap way to pass the programming from my theater (specifically Apple TV {HDMI)and a Mac Mini {DVI}hooked to a 4TB pseudo SAN) rack to each of these TV's over coax..
Hard to justify 4 new Apple TV's.. and the LCD's with just coax get most cable channels and some HD channels already.
ATSC Modulators are of course out of the question. You'd think I could push content from a central rack onto the coax network and let the LCD's decode it and publish on an open channel... and 480i would be fine for Barney and Little Einstein videos.. ;-)
Any input is appreciated.
Greg Miles
gmiles is offline
Old 04-02-2009, 07:31 PM
Steely's Avatar
I use the Rapidrun system and they work great. You buy the cable which comes with the metal caps (including pull loop) and then you buy the ends that you need which just screw on. They are just 5 mini coax inside. They are nice because if you want to switch to SPDIF instead of analog audio you just buy a new end.
http://www.amazon.com/25-Rapidrun-CL.../dp/B000F6MOLC
I have two of these and the picture quality is flawless.
Steely is offline
Old 04-02-2009, 07:37 PM
magin's Avatar
How to convert MOD is a hot topic for many JVC/Panasonic/Canon digital camcorder users. Generally speaking, to convert MOD file,
we need a Convert MOD - Aiseesoft MOD Video Converter which can convert MOD video files perfectly and quickly.
Have this MOD Converter, you can convert MOD video files to all popular format files like AVI, MPG, WMV, MOV, FLV, Mp4 and so on.
Besides MOD file, you also can convert TOD, TS, MPEG, MPG, MPV, MP4, VOB file to all popular format with this MOD Converter.
Moreover, this MOD Converter also provides powerful edit functions, you can freely cut your MOD, join MOD before you convert TOD to other format.
magin is offline
