Dishnetwork receiver to 3 tvs (composite to amp slitter or hdmi over cat6 and split) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-13-2009, 08:15 PM - Thread Starter
swicked's Avatar
I will be upgrading to HD and getting a DishNet receiver with Dual tuner and DVR.
I plan on running my theater tv via tuner 1 hdmi out.
I have 3 other tvs in my basement (1 in work out room and 2 beside shuffleboard table) in which I want to all have the same feed.
What is my best way of accomplishing this - with out going crazy on things. I will be purchasing my cables from Monoprice.
I was considering:
1) using composite and splitting it 3 times and making 3 long runs (using a CE LABS AV 400COMP High-Performance Component/HDTV Distribution Amplifier)
or
2) hdmi over 2 cat6 (run into hub - to split 3 times) to hdmi out
which do you suggest
THANKS
swicked is offline
post #2 of 4 Old 04-13-2009, 09:43 PM
umdivx's Avatar
umdivx is offline
post #3 of 4 Old 04-14-2009, 05:19 AM - Thread Starter
swicked's Avatar
They are going to be HD tvs - and i would like to get HD signal to them (bearing in mind the cost)
swicked is offline
post #4 of 4 Old 04-14-2009, 05:56 AM
umdivx's Avatar
was going to say if it was SD, that is simple as the Dish boxes you can run secondary tv's off of their boxes via coax and tune them to a specific channel, but since this is HD, it is a little more tricky.
I think you are on the right path with the component or HDMI over cat5. Just all depends on how much you want to spend.
- Josh
umdivx is offline
Reply Home A/V Distribution
