Recommend a 2Ghz 8 Way Drop amp... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-24-2009, 03:29 PM - Thread Starter
santora's Avatar
I'm wiring up the house and have a little cabinet set aside from all ethernet / cable / telephone connections. And while right now I'm only running digital cable (which I know only needs 1Ghz attenuation) - there's a possibility of moving to Dish this year sometime. And right now I'm also getting my internet via the Cable company - also could change...
So If I'm going to buy the unit, I'm going to do it right the first time. You know, have a little headroom for the future.
Now I've been looking and keep coming up against the 1Ghz barrier in 8 way drop amps. Is this inherent in all drop amps or am I not looking in the right place?
Mark Santora
santora is offline
post #2 of 3 Old 04-25-2009, 07:20 AM
egnlsn's Avatar
Quoted: 146 Post(s)
Liked: 66
There are no 8-output drop amps that have a bandwidth of 5MHz-2GHz. If you do go with satellite, you won't need an amp as many 8-output multiswitches have internal amplifiers. If it's a SWM with DirecTV, the receivers can be up to a couple hundred feet from the SWM module.
Your cable modem line should not be amplified, so you wouldn't need one that goes down that low, anyway.
CIAO!
Ed N.
egnlsn is offline
post #3 of 3 Old 04-26-2009, 10:22 AM - Thread Starter
santora's Avatar
Ed.
Thanks for the reply man. I was pretty certain I would be ok - but I just wanted to make sure I wasn't dropping the coin on something that wouldn't be what I need in a few months.
Mark
santora is offline
Reply Home A/V Distribution
