Actiontec MI424WR - a cheap MoCA bridge for all! - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #391 of 1262 Old 02-07-2010, 10:17 PM
Hypnosis4U2NV's Avatar
Given the fact that so many of these DOA boxes are in the wild, they may have hardware issues which may cause them to die..
So far all 3 of mine are running fine.. (knock on wood)
The length of a film should be directly related to the endurance of the human bladder. ~Alfred Hitchcock
Hypnosis4U2NV is offline
post #392 of 1262 Old 02-08-2010, 07:18 AM - Thread Starter
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
Yeah, however I think I have seen a pattern with a particular eBay seller and issues... I don't want to name names without evidence though - so perhaps those with issues can say who they bought their bad unit from?
xnappo
xnappo is offline
post #393 of 1262 Old 02-08-2010, 12:34 PM
dahacker's Avatar
xnappo
My advice is to just get them from sellers on eBay that are just selling them because they just moved out of a FIOS area or just got rid of their FIOS service for other reasons. Those sellers are pretty easy to identify and you know the unit worked up till the day they disconnected. I got three rock solid units using that selection method.
Why gamble on a guy that has piles of them and frankly probably has no idea how to make sure they work right.
dahacker is offline
post #394 of 1262 Old 02-08-2010, 01:42 PM - Thread Starter
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
I concur.
xnappo
xnappo is offline
post #395 of 1262 Old 02-09-2010, 08:53 AM
pcanters's Avatar
Is it possible to run the MI424WR boxes as a MOCA bridge and then to also use the wireless G for PC Client access ??
That way the client can connect to the far end wireless G and ride the coax bridge to get to the internet.
Is anyone doing this ?
pcanters is offline
post #396 of 1262 Old 02-09-2010, 11:45 PM
joeblough's Avatar
xnappo
yeah clearly it was a salvage operation... but at the time that was the only seller on there. they never misrepresented themselves - it was clear that they were surplus. and when the one arrived DOA they just sent me another one right away.
i decided to try my luck with the netgear boxes. i dont know if they have the same moca chipset or if there's a newer one out there... but it turns out my cable network was kind of on the edge. i put in one more splitter and the moca connection became unstable. maybe things will improve with the netgear boxes, who knows.
joeblough is offline
post #397 of 1262 Old 02-10-2010, 03:34 AM
kevinelliott's Avatar
I just purchased a lot of 7 units on eBay (without power adapters). Can anyone suggest a place to buy some? I searched for over an hour, and the only one I found was for $14.95 new plus $14 shipping. That was steep!
kevinelliott is offline
post #398 of 1262 Old 02-10-2010, 07:24 AM - Thread Starter
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
You just need one that matches the specs... I will try to remember to post them tonight. I do remember that they need to be 3A - I tried a 2A one and it did not work.
xnappo
xnappo is offline
post #399 of 1262 Old 02-10-2010, 05:56 PM
Yep, 5V 3A 15W. However, I don't know the size of the tip. Also, I can't seem to find places to buy these power adapters for CHEAP! Looked on ebay, google, etc. Lowest prices seem to be around $15+shipping, which I think is fairly steep. If I have to, I'll settle, but I'm sure there's got to be somewhere selling them for like $5 each.
post #400 of 1262 Old 02-12-2010, 02:45 PM
dahacker's Avatar
Be careful, the E version requires 10VDC, 1.6A
dahacker is offline
post #401 of 1262 Old 02-18-2010, 03:59 PM
wbassett's Avatar
Location: Been all over. Currently living in upperstate NY in the Capital District area.
Great thread, thanks xnappo this may be exactly what I am looking for!
I have a 167 year old Victorian with lathe and plaster walls, so running cat5 throughout the house isn't a viable option (mainly running upstairs to downstairs).
Here is my setup- my main Media PC is upstairs as is my media storage server. I do all my editing and PVRing with my Hauppauge 1212 in my office/workshop. Downstairs is my HT setup and the PS3 I want to stream everything to. Also I will have a WDTV or equivalent type device in the other bedrooms but they are wired with Cat5e.
I do have a couple of questions though.
First- I have Time Warner everything- Cable, phone, Internet... Will this interfere with that since I am already using my cable for Internet and phone?
Next, for those using the Motorola NIM100, what switch are you using and how are you handling IP addresses for the attached devices?
"Make everything as simple as possible, but no simpler." - Albert Einstein
wbassett is offline
post #402 of 1262 Old 02-18-2010, 04:43 PM - Thread Starter
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
Hi - don't know the answer to the NIM100 question - but TWC should present no issues other than the issues inherent to adding more splitters. All the TWC frequencies are below 1Ghz. This uses frequencies about 1GHz.
xnappo
xnappo is offline
post #403 of 1262 Old 02-24-2010, 11:45 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
xnappo
I got a bad one from eBay user "mecenasplnj". He's jerking me around about it now. I'll probably have to file a dispute with eBay or Paypal.
[edit: he gave me a refund and told me to keep the broken router. I don't think it was a scam.]
ScottJ is offline
post #404 of 1262 Old 02-25-2010, 12:00 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Tip Size: Inside:2.8mm Outside: 5.5mm
5V 3A (more than 3A should be fine too, but must be exactly 5V)
I got one from eBay user "emtcompany". The model is CHI CH-503 and I paid $10. Be careful because it might not come with the AC cord. I happened to have a matching one in my big box of cords.
The tip size specs are from the auction description for the CH-503 which is currently powering one of my MI424WRs. Keep in mind this is for the older MI424WRs only, as pointed out above.
I just got my two hooked up from one end of the house to the other and it's working great! All thanks to this thread!
ScottJ is offline
post #405 of 1262 Old 02-25-2010, 06:31 PM
I found a 5V 2.5A for another router somewhere. Plugged it in to one of these old MI424WRs and it seems to work.
Anyone know if 2.5A will cause problems long term?
post #406 of 1262 Old 02-26-2010, 03:54 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
I have a fios actiontec 414 router and bought a Motorola NIM-100 off ebay and added it to my network to add connectivity to media server in a closet where it is very hard to run CAT5. It was plug and play, found the network automatically and I can now dl and ul my full 35/35 to that server.
My problem now is that I get a huge amount of stuttering streaming 1080p mkvs from that server to my three popcorn hour NMTs. This was surprising to me as those mkvs are even less bitrate than my maxed out fios DL speed of 35 mbit/s.
I read about people getting like 150-200 mbit/s throughput over moca so it is a little disappointing to me so far for the purpose of streaming video. Even 100 mbits would be plenty for me to stream high bitrate mkvs as that was what i was doing previously over Cat5 with no issues.
I just cannot think of a reason why I would get such stuttering on 20-30mbit bitrate video files over moca. Any thoughts?
Also, what program can I use to check the throughput to the NIM-100?
_____
Update: Also, seems like many people are having similar issues with streaming over moca, as I read the entire thread now - sorry about posting before reading it all. I guess I am not alone.
Davecraze is online now
post #407 of 1262 Old 02-27-2010, 01:56 PM
chewyboy's Avatar
Great thread, i am looking into hooking up an out building for networking but need a bit stability than wireless can give me. the building is about 300 or so ft away from where i currently have a house wired. what i am curious about is if i run a rgb6 cable from one building to the other, no splits good stuff, can the 424wr handle that type of distance over coax and what types of speeds can i realistically expect to get? I was looking at the gefens but this seems to be a much more affordable solution.
thanks
edit: i don't care about the video at all, i just need data over the coax.
chewyboy is offline
post #408 of 1262 Old 02-28-2010, 07:04 PM
You should be within specs of the MoCA standard and should see decent speeds assuming you dont split the connection from one point to the other..
As far as streaming 1080P movies (MKV's or whatever) --- It seems that this affects a large majority of people with these routers, including myself.. 720P plays back fine, but I get stuttering on 1080P MKVs, MP4s, M2TSs.. On a 90 Mb/s connection, I still get stuttering.. This setup is not perfect or without its problems, but it sure beats wireless and powerline.. And I am perfectly content with streaming 720P movies and full broadband access from locations that would have made running cat5e a nightmare..
post #409 of 1262 Old 03-01-2010, 03:20 PM
Barometer's Avatar
Hello all, my first time seeing this thread. Has there been discussion about filtering the MoCA band at the home's point of entry to prevent the signals from travelling upstream to your neighbors? Since MoCA operates at a higher frequency than CATV I don't think there's anything in the line to prevent pass-thru. I'm not sure a cable operator would provide a MoCA filter at the drop if they don't offer MoCA service (that would be a ton of filters for them to install).
Barometer is offline
post #410 of 1262 Old 03-01-2010, 03:26 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
From the first post:
If you are worried about security, you may want to enable privacy:
My Network->Network Connections->Network(Home/Office)->Settings->Coax
Select 'privacy' and set the password. Make sure this is the same on all the routers.
ScottJ is offline
post #411 of 1262 Old 03-01-2010, 03:35 PM
Barometer's Avatar
post #412 of 1262 Old 03-01-2010, 08:11 PM
chadw01's Avatar
I believe if you use a drop-amp simliar to this, that you can segregate your MOCA traffic at the point of entry.
Go to where the cable runs into your house, and put the amp there.. you can also use the Privacy switch with password on all the Actiontecs as ScottJ mentioned.
chadw01 is offline
post #413 of 1262 Old 03-01-2010, 08:58 PM
chadw01's Avatar
Anyone use/using the Westell 9100EM for MOCA bridging? How does it co-exist with the Actiontec? Looking to pick one of these up on eBay as I hear they use beefier hardware and are much faster..
Also, I was reading a thread which I can no longer find (believe it was on dslreports that mentioned the administrative ports being left opened on the Actiontecs.. forgot the port #..) - basically an admin port for Verizon techs to backdoor into the boxes.. anyone know about this?
EDIT: I found the dslreports link: http://www.dslreports.com/forum/r235...n-new-firmware
It is port 4567..
chadw01 is offline
post #414 of 1262 Old 03-02-2010, 09:00 AM
chadw01's Avatar
From Ebay..
$9.99US + free shipping (China):
http://cgi.ebay.com/Actiontec-power-...item5ad78afc30
Apparently VZ was recalling the power supplies and replacing them with ones marked "A1" in the lower-right part of the label under the bar code.. the guy selling these ones show only "A".
Caveat emptor.. YMMV.
chadw01 is offline
post #415 of 1262 Old 03-06-2010, 11:51 AM
wbassett's Avatar
AllElectronics has a 5VDC 3.7A adapter for $4.75. Part# is CAT# PS-537
Has anyone tried this one?
wbassett is offline
post #416 of 1262 Old 03-06-2010, 11:01 PM
chadw01's Avatar
This?
http://www.allelectronics.com/make-a...UPPLY/-/1.html
This review doesn't think too highly of it:
Not a good unit
This supply is supposed to be a 3.7A 5VDC output. Well it isn't. I tested it on my homemade test bed, and it can only put out 1.5 amps before the voltage starts to drop. At 2 amps load, it put out 4.85 V. That's a 19% drop from it's no load output. A switching power supply should have less than a 5% drop when loaded. SO beware!! I'm going to find another 5V supply that has better regulation.
You need 3A... but at that price, I guess it is worth a try (if you don't mind the risk).
chadw01 is offline
post #417 of 1262 Old 03-07-2010, 01:12 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Originally Posted by chadw01 View Post
This?
Not a good unit
That reviewer must be using the New Math. 4.85V is only a 3% drop from 5.00V, not 19%.
ScottJ is offline
post #418 of 1262 Old 03-10-2010, 07:50 PM
Franke46's Avatar
This looks like a great solution for my house I just have one question, if I use it to bring network service to a place where I have 2 devices (bluray player and htpc) can I connect both to the auctiontech? Or what would I need to make it work?
Franke46
Franke46 is offline
post #419 of 1262 Old 03-10-2010, 08:09 PM - Thread Starter
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
Franke46
Yes you can. There are four ports.
At this point, I would really recommend you pay the extra $10 or so on eBay for a rev c or d. Many here have had the rev A. go out after a while - I myself just had one go out a couple of days ago. If you do get a rev A - don't pay more than $20.
xnappo
xnappo is offline
post #420 of 1262 Old 03-10-2010, 08:40 PM
Franke46's Avatar
Thanks a lot xnappo, I've seen a few locally, they are the better looking, round ones so I suppose they are the newer revisions.
Your posting is a really great contribution to avs, it should be a sticky somewhere.
Franke46
Franke46 is offline
Reply Home A/V Distribution
