switch for 5.1 speakers between xbox + pc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-30-2009, 10:35 PM - Thread Starter
spizza's Avatar
currently im sharing a pair of 5.1 logitech speakers between my xbox and my pc.
every time i switch device, i have to get under my desk, go through the jungle of cords and cables and manually switch to the other device. its fairly annoying as i can be switching device every 10 minutes or so.
do they sell switches that will allow me to switch between them? i dont want to use a splitter on its own, because ive read that it can blow my speakers up. so id need a splitter with a switch.
if they dont sell these off the market, or are easy to obtain, how can i make one? im not too great in this area, but im not that bad either and think that i could do something like this. id just need to know what id need to make one.
spizza is offline
post #2 of 3 Old 07-01-2009, 03:08 PM
Adidas4275's Avatar
well if it were a normal 5.1 setup and AVR would work, but since its a logitech i am not sure.... the more expensive logitech setups have multiple inputs.... i am guessing yours is not.
is you setup all analog connections?
Adidas4275 is offline
post #3 of 3 Old 07-01-2009, 09:26 PM
gjvrieze's Avatar
Something similar to this is what you may want to do.
KD0MOF
All opinions expressed (unless otherwise noted) are the poster's only and NOT that of the poster's employers.
gjvrieze is offline
Reply Home A/V Distribution
