"Wirelessly" stream xbox to 2nd tv - AVS Forum | Home Theater Discussions And Reviews
Old 11-21-2009, 06:48 AM - Thread Starter
festis88's Avatar
I have searched around and have not yet found an answer, so here's my scenario.
I have my xbox 360 hooked up to my living room home theater via hdmi. i have a second hdtv in my bedroom that is literally 15-20 feet from the xbox (bedroom and living room share wall). I have already tested and confirmed that the remote works from where i'd be playing in the bedroom (I had my wife watch the screen to see if my character was moving).
So what I want to do is be able to wirelessly stream the a/v from the xbox to the bedroom tv. Additionally, the living room tv is 1080p, bdroom tv is 720p, in case that will change things. Lastly, cost is a factor, i.e. cheapest way possible please.
festis88 is offline
Old 11-22-2009, 06:01 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
If cost is the factor then getting a HDMI splitter and a long HDMI cable is the cheapest.
Otherwise there are some wireless HD solutions thats available like the Brite-View BV-2500 Wireless HD Video Transmitter and Receiver Kits.
JChin is offline
Old 11-24-2009, 10:06 AM - Thread Starter
festis88's Avatar
Thank you for the information. That is a little steep for my budget. Unfortunately, I think I'll have to go with the wired solution.
festis88 is offline
Old 11-24-2009, 10:29 AM - Thread Starter
festis88's Avatar
One more question.
I currently have my xbox hooked up via HDMI and optical out. If I add an HDMI splitter and then run one signal to my bedroom, will that HDMI carry the sound as well? My concern is that by using the optical out for surround in my living room, the HDMI from the xbox will only be carrying video signal. Anyone know if that is the case?
festis88 is offline
Old 11-24-2009, 10:56 AM
Stef1966's Avatar
Originally Posted by festis88 View Post
One more question.
Yes. My XBox is hooked up via HDMI to my LCD Display. I also have the optical out connect to my receiver. I always have sound on the tv from the HDMI cable.
Stef1966 is offline
Old 11-24-2009, 12:06 PM - Thread Starter
festis88's Avatar
Sweet, thanks.
festis88 is offline
