Can I connect a Fios STB via Cat5? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2010, 02:54 PM - Thread Starter
yowzator's Avatar
I have Fios service with two STB's (a home media DVR and an HD tuner). Currently they are both connected via coax. I want to move the tuner (Motorola HD QIP 7100 1) to a different location, but there is not currently a coax cable going to that location. I do have a cat5 connection at this location, and the 7100 has an ethernet port.
Is it possible to get full TV service via the cat5 connection on this STB? If so, how? Will I still be able to stream recordings from the home media DVR if I do this?
yowzator is offline
post #2 of 5 Old 02-23-2010, 03:36 PM
mrted46's Avatar
Quoted: 30 Post(s)
The cat5 port on the STB is for data only (such as guide) if you decide or can't use MOCA.
mrted46 is offline
post #3 of 5 Old 02-23-2010, 03:56 PM - Thread Starter
yowzator's Avatar
Thanks for your help. So I take your answer to mean that I will need to run a coax cable to the new location if I want video.
However, I don't fully understand what you mean by "if you decided or can't use MOCA". What use is the STB without video? Why would I want just the data connection but not the video?
yowzator is offline
post #4 of 5 Old 02-23-2010, 04:18 PM
mrted46's Avatar
Quoted: 30 Post(s)
The Verizon STB collects data such as channel guide, on demand, etc. Without this information you obviously will not have a channel guide and all the features of the STB. MOCA allows this data to pass through the coax, along with the video signal so by default all you need is the coax and you will have everything Verizon has to offer.
In some cases, amplifiers or splitters do not allow the MOCA to work, therefor your alternative is to use Cat5.
mrted46 is offline
post #5 of 5 Old 02-23-2010, 05:37 PM - Thread Starter
yowzator's Avatar
Ok, thanks. I get it now.
yowzator is offline
Reply Home A/V Distribution
