Distributed Audio/Video install - FAIL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-07-2010, 01:11 PM - Thread Starter
Fiasco's Avatar
Job: Expand in house Russound distributed audio system to include the pool house (six speakers, TV, uverse, ipod ect)
Step 1: Locate, inspect and document the existing setup that must be tied in to.
Step 2: Shake head in disbelief.
How do you even put a bid number to something like this?
The equipment is installed in a 20' long built in cabinet that no doubt cost several thousand dollars. The equipment w/ cables attached did not fit the cabinet. Installers solution? Cut the back out of the built in, remove the drywall and cut notches into the studs.
Stuctured wiring is outstanding as well (very cleverly disguised as a heap of wire and power transformers adjacent to the equipment)
If this was a homeowner attempt at an install I could understand but this was purportedly put in by "professionals" (who have a competing bid btw for the poolhouse expansion)
St Louis, MO - Lutron certified
www.jag-es.com
Fiasco is offline
post #2 of 5 Old 05-07-2010, 07:56 PM
39CentStamp's Avatar
I dont get it.. they even took the time to put electrical tape on the emitters to hold them on.. talk about attention to detail
39CentStamp is offline
post #3 of 5 Old 05-08-2010, 07:39 PM
bigpapa's Avatar
I've studied that photo for several hours now. I cannot find a winner between:
Lick n Stick
Slam n Jam!
Unbox, hook up, wazzup!
Entry for CEDIA award: Fastest and Cheapest DA Install
bigpapa is offline
post #4 of 5 Old 05-08-2010, 08:19 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
CE Pro Neat-O! before picture?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 5 Old 05-10-2010, 08:14 AM - Thread Starter
Fiasco's Avatar
I will be sidestepping this system entirely. Owners aren't interested in setting it up properly right now.
www.jag-es.com
Fiasco is offline
Reply Home A/V Distribution
