HDMI over Cat5e problems and solutions, read before posting - Page 15 - AVS | Home Theater Discussions And Reviews
post #421 of 436 Old 12-22-2014, 08:01 AM
HDgaming42's Avatar
Quoted: 150 Post(s)
Originally Posted by dw886 View Post
For anyone wondering, I ordered a few of these "HDMI Voltage Inserters" to try instead of using the 8154 Splitter / Amplifier from Monoprice to "boost" the signal, as it would allow me to clean up my A/V rack some. It *did not* work. It probably does what it states that it does (inserts some additional voltage), but it didn't have the same effect as the 8154, and was not enough to drive the 8008 wallplates...
Thanks for reporting back. I wonder if I bought an 8154 my baluns would "come back to life"...
HDgaming42 is offline
post #422 of 436 Old 12-23-2014, 03:36 PM
louder's Avatar
Liked: 0
How do I control 2 devices via IR using HDMI extender
Need help here. I need to control a cable box and stereo receiver using IR control via an HDMI over single Cat 5 extender kit. The kit I am using is a 5 volt unit that has an IR sensor eye, and a single IR emitter. When I try to swap the single IR emitter with a dual IR emitter, I am only able to control one device, not both.
Any thoughts?
Thanks in advance.
louder is offline
post #423 of 436 Old 12-25-2014, 10:32 PM - Thread Starter
audiodane's Avatar
Quoted: 47 Post(s)
Liked: 61
FWIW, an HDMI Voltage Inserter does NOTHING to the data signal, as far as I understand it. All it's doing is inserting the +5V signal on the +5V signal path on the HDMI cable. Therefore an HDMI Voltage Inserter can be used to power a downstream device that gets its power from the HDMI channel itself if by chance the source device can't deliver the rated current that the HDMI spec requires to be "compliant." So, I'm not surprised that an HDMI Voltage Inserter is doing nothing to help signal strength or integrity. An HDMI amplifier may be an interesting combination with some of the baluns, though I have a sneaky suspicion that if it were that easy, it would been solved by now? Maybe I'm just being pessimistic..
..dane
audiodane is offline
post #424 of 436 Old 01-02-2015, 08:48 PM
Liked: 0
Hello.
So after reading about HDMI extenders and HDMI over TCP/IP, I decided to try to connect my desktop computer (GTX680) to my HDMI television on the second floor. I'm thinking on using this product --> http://mobidick.su/en/katalog/elemen...LEMENT_ID=2305 (there are tons selling on Ebay), as this works over TCP/IP, and I can use my existing Gigabit Ethernet network (with some switches in the way).
This is the usable bandwidth between the two points:
My question is, what can I expect from this product? Will the image quality be the same, or will compression be excessive and noticeable and I will experience a lot of blackouts?
With that bandwidth, can I expect to achieve 1080p@60Hz between the two points without interruptions?
Best Regards.
Ebay is offline
post #425 of 436 Old 01-03-2015, 07:47 PM - Thread Starter
audiodane's Avatar
Quoted: 47 Post(s)
Liked: 61
Originally Posted by Ebay View Post
Hello.
Best Regards.
I'm not an expert on the HDMI spec, but a 1080p signal is somewhere around 10Gbps uncompressed max. So for sure the device you're looking at cannot handle that.. There will certainly be compression requirements. The real question is how much, and how bad. Amazon Prime streams 1080p at around 8Mbps and while it doesn't quite rival a good transfer on bluray, I have to say after watching it for the past three weeks with my wife almost every night (binging on Avatar animated series, Parenthood, and Dr. Who), on a 50" TV from a viewing distance of around 15-17ft, it still looks awesome.
So the questions are more along the lines of 1) what are your use cases and 2) what are your expectations? The answers to those two questions will help guide your decision about this product.
If there's any way to get a unit with a decent return policy, it would be a nice safety net in case the device doesn't perform up to expectations (regardless of what the specs say).
cheers,
..dane
post #426 of 436 Old 01-05-2015, 05:22 PM
Liked: 0
cheers,
..dane
Hi.
After reading this article about that unit, I'm going to pass --> http://api.viglink.com/api/click?for...ip-extender%2F
It was too good to be true
Ebay is offline
post #427 of 436 Old 01-07-2015, 09:34 PM
AV Hack's Avatar
Quoted: 65 Post(s)
Liked: 27
Hi.
Good call.
Working on the next one...
AV Hack is offline
post #428 of 436 Old 01-08-2015, 07:55 AM
1C5
1C5's Avatar
having a strange issue. I have a rather long HDMI run from TV to media rack in basement (maybe 75 feet)...
first tried hooking up a 60" Pioneer Plasma to various sources and was getting bad noise.
Then I tried with a different TV...a 60" Samsung plasma. The HDMI cable worked perfectly in 1080p. No issues.
And now I got a new TV, an 80" Sharp LCD and having issues again with the HDMI signal. Picture is cutting in and out. Wondering what you suggest i try to get the Sharp working with this HDMI cable. Why did the Samsung work perfectly and the Pioneer and Sharp have issues with the same HDMI cable?
Also I have 2 extra unused cat5e lines running to the TV if those can be used for anything.
Please help!
1C5 is offline
post #429 of 436 Old 01-09-2015, 11:12 AM
SMHarman's Avatar
Quoted: 211 Post(s)
Liked: 62
The 2 CAT5e can be uses for HDBaseT oR cheaper Baluns.
SMHarman is online now
post #430 of 436 Old 01-09-2015, 08:32 PM
Liked: 0
Projector distortion from HDMI extender
I'll send this to you all while I have a little hair left...
I currently have 2 projectors hooked up using the following setup:
Laptop (HDMI) > J-Tech HDMI Splitter> J-Tech HDMI extender> 90' Cat6 UTP> HDMI Receiver> HDMI Cable> Front Projector
Identical setup to rear projector, except the distance is about 30'
Current problem: Front projector looks beautiful, no issues. Rear projector shows distortion/lines anytime there is an image on the screen.
Troubleshooting steps:
Laptop plugged directly into projector via HDMI: works great
Laptop HDMI plugged directly into rear extender (bypassing splitter): distortion on rear
Temporary CAT6 cable ran from rear extender to rear receiver: distortion on rear
Transmitter, receiver and projector all connected temporarily to same power source (8-port power conditioner): distortion on rear
Swapping transmitter/receiver from front projector: distortion on rear
Lower resolution on laptop: distortion on rear
Tried swapping HDMI cables, plugins, etc.: no change
I spoke to J-Tech's tech support and they are happy to send out a replacement, but since the front has always worked great, even on the transmitter/receiver from the rear projector, I don't think this will help.
I'm not real sure what to try next (other than HDbaseT) and still stay within budget. Has anyone else come across anything similar?
I don't want to finish building the rear screen until I can get all the bugs worked out, so we are projecting on the regular wall for now.
Mike Ely is offline
post #431 of 436 Old 02-03-2015, 12:14 PM
Liked: 0
stuttering only on certain content
Quick question. I just successfully installed an HDMI over Cat5e converter, and it works great for streaming almost all of my media via PS3 app delivery (I have an older Sony TV without the apps found on the PS3).
However, while I can see very high framerate mp4's via PS4 delivery, I have noticed that some content from amazon, mostly TV based content, stutters when I try to use this, even though movies streamed via Amazon prime, have no such problem.
Have you ever had experience where some content streams flawlessly, and some does not? Is there a content mismatch possible. I am using a relatively high end Snap system.
Thanks. Before I go out and have to buy some new TV, I thought I'd ask here.
pmoyers is offline
post #432 of 436 Old 02-03-2015, 12:29 PM
Joe Fernand's Avatar
Quoted: 68 Post(s)
Liked: 76
Connect the Source direct to the TV via a High Speed HDMI cable and rerun the test!
Joe
audiodane likes this.
If I've helped 'Like' me on Facebook - www.facebook.com/Octavainc
Joe Fernand is offline
post #433 of 436 Old 02-04-2015, 09:09 AM
Liked: 0
Cat5E Crimping....
Hello all, just had a question regarding the Cat5E crimping method....
I purchased a 500ft bulk spool for Cables2Go Cat5E Plenum Cable. I'm using the Sabrent HDMI-EXTC adapter. I was wondering if one method of crimping the Cat5E is more suitable for video/audio. T568A? T568B? Somehting else? Does it matter? Thanks in advance!
mattk1102 is offline
post #434 of 436 Old 02-04-2015, 02:20 PM
Quoted: 68 Post(s)
Liked: 76
The Installation Manual for the Extender will/should indicate which wiring scheme to use.
Joe
post #435 of 436 Old 02-10-2015, 05:11 PM
Liked: 0
It doesn't really matter as long as it's the same on both ends...I find that most people use B so I use it too..
Cjorgy is offline
post #436 of 436 Unread Today, 07:32 PM
Liked: 0
HDCP issue with Mac/AppleTV using HDMI zone out
I have a family room Yamaha AV receiver (A3000) and a basement Yamaha AV receiver (A2030). AppleTV in both spaces, and a Mac Mini media computer in the Family room.
I have run HDMI over EtherNet (Cat6e) both up and down between the receivers (though the A3000 only mirrors the zone out with the main out HDMI, while the A2030 allows the zone out source to be set independently.)
The gist is this:
The Mac Mini input, and also the AppleTV input show HDCP handshake issue blinking while the HDMI over Ethernet (HoE) connection from the HDMI zone output is connected. The blinking stops and output is perfect, when I unplug the HoE from the receiver HDMI 2 out. The problem occurs when the output is connected, but even though the signal is not actually being used (source selected) in the other room.
Output from other sources (Wii U) and Blu-Ray player (Oppo) work just fine with the HoE connection in place.
Unfortunately, this means that the HoE connection must be left unconnected to use the Mac or AppleTV (which is nearly always.) I only can connect when specifically wanting to share signal between the rooms from one of the (non Apple) working sources (which is a pain.)
HoE used is:
8121 - HDMI® Extender Using Cat5e or CAT6 Cable.
Cat6e cables are stock pre-terminated cables of about ~35 feet length.
I have unplugged and rebooted all devices (multiple times.)
Both receivers have had firmware updates.
Both receivers have had the HDMI up-scale limits set to skip.
Cabling is clearly ok as some sources work perfectly.
Any ideas or suggestions?
Thanks in advance!
parkerjd is online now
Reply Home A/V Distribution
hdmi extender , hdmi over cat6 , Iogear Vga Cat5e 6 Audio Video Receiver Gve140rx Black
