Adding TV to upstairs bedroom, is a wireless Direct TV solution available? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-25-2010, 12:59 PM - Thread Starter
maldini99's Avatar
I am currently a Direct TV customer. We have one SD box in the family room and one HD box in the basement.
We would like to add a TV to one of the bedrooms upstairs, but for many different reasons we can not wire to it.
Are their any viable wireless solutions where we could transmit the output of one of our other two boxes to our upstairs TV and then maybe control the far away box using an RF remote?
Thank you for any help or suggestions.
maldini99 is offline
post #2 of 8 Old 10-25-2010, 01:08 PM
Techaholic's Avatar
Brite-view BV2322 (Air syncHD) see thread http://www.avsforum.com/avs-vb/showthread.php?t=1279447 below it work great for that as long as you get a good signal.
Techaholic is offline
post #3 of 8 Old 10-25-2010, 01:16 PM
crutschow's Avatar
Do you want HD or SD to the bedroom? SD is a lot easier.
Carl
Curmudgeon Elektroniker
crutschow is offline
post #4 of 8 Old 10-25-2010, 02:25 PM
fletch999's Avatar
Slingbox?
fletch999 is offline
post #5 of 8 Old 10-26-2010, 09:23 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Originally Posted by fletch999 View Post
Slingbox?
Good luck finding a Slingcatcher, it's been discontinued. So, that would mean connecting a laptop up to the remote TV....probably not the solution maldini99 is looking for. If SD is acceptable you can get an A/V sender like this one, (probably what Carl was alluding to) otherwise, the Brite-view that Techaholic suggested might be a consideration.
Vin
Vin is offline
post #6 of 8 Old 10-26-2010, 03:42 PM
crutschow's Avatar
For remote control, DirecTV sells an RF remote for $25 ($22 with an NFL team logo of your choice) that will operate their receivers and also the local TV. It works well for controlling my box inside a closed cabinet. Not sure what its maximum range is though.
Carl
post #7 of 8 Old 10-26-2010, 04:20 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Just note that if you put the DirecTV receiver into "RF Remote mode", it no longer responds to IR. So you have to use their RF remote(s) exclusively in that configuration...
Jeff
jautor is offline
post #8 of 8 Old 10-26-2010, 04:33 PM
crutschow's Avatar
Didn't know that. Means you'd have to buy an RF remote even for in the same room as the receiver.
Carl
Reply Home A/V Distribution
