How to best connect Apple TV to Russound CAV 6.6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-06-2010, 10:18 AM - Thread Starter
ghtaylo's Avatar
I have a russound cav 6.6 and would like to connect my apple tv to it. The problem is apple tv is a component video. The cav uses composite video. I have found a switch for $150 that suggest it will switch the component video to composite. Is this the best approach?
I distribute the video from my CAV today via coax. Any suggestions would be appreciated.
ghtaylo is offline
post #2 of 3 Old 02-18-2012, 02:50 PM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 129
Don't suppose there is a good way to do it. The AppleTV outputs are high-def. You'd have to get a device that converted a high-def picture down to the low-res format necessary for composite video. I'm sure someone out there makes a converter that will do it, but to what end? You'd end up with a terrible looking picture.
wkearney99 is offline
post #3 of 3 Old 02-18-2012, 10:40 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
How about an old AVR that does video cross-conversion? I think most could down-convert component to composite.
cshepard is offline
Reply Home A/V Distribution
