HDMI video distribution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-18-2010, 09:51 AM - Thread Starter
pointdexter02's Avatar
I'm new to the community. I wanted to see if anybody could help me out with the distribution system I'm designing for my house. I've attached a quick diagram of what I'm thinking. Chime in if you see problems with it.
All TV's are 1080P and the living room is going to be a 3D plasma. I am looking at using a monoprice 4x4 so I figured I'd need a splitter to send a dedicated line straight to the receiver/tv for 3d.
My question is, will that 1.4 splitter send the proper signals to the receiver or will it see the rest of the stuff on the network and downgrade. Also, is there any fairly cheap way I can "decode" the audio at each leg, so that I can get surround at the living room?
pointdexter02 is offline
post #2 of 14 Old 11-18-2010, 11:54 AM
AI Limited's Avatar
Why are you splitting the PS3? In theory, I believe a 4x4 matrix would look at all your displays and output 1080p if the source is 1080p, not a lower resolution if that's what you mean by downgrade.
AI Limited
AI Limited is offline
post #3 of 14 Old 11-18-2010, 12:18 PM
ChrisWiggles's Avatar
1) HDMI distribution is a clusterf**k nightmare. HDMI distribution isn't even in my vocabulary.
2) as far as audio, yes it will see the TVs and downgrade everything to stereo. You will need a separate SPDIF out for 5.1 and will not get high res. Or you will need to have a more advanced switcher that can make sure all the outputs are physically off to the TVs so they aren't seen by the sources.
Basically, if you want to distribute stuff, distribute component video and stereo analog audio to the TV. Do 1080p HDMI locally only.
Or you're asking for an ass-kicking.
ChrisWiggles is offline
post #4 of 14 Old 11-23-2010, 02:51 PM
AI Limited's Avatar
Ha! That's hilarious! You crack me up Chris...
I guess you aren't buying into distributing a Blu-ray changer?
Obviously we can't distribute 1080p or DTS-MA/Dolby TrueHD without HDMI, which would be my nirvana.
AI Limited
post #5 of 14 Old 11-23-2010, 03:43 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
And I think Chris means kicking by HDMI, not by Chris himself...
Especially if you're considering 3D support, you should just assume those source(s) would need to be dedicated to the 3D-capable system.
If you take some of those things out of the distribution equation (such as 'real' 1080p / DTS-MA content), simple component video solutions can handle everything else...
Jeff
jautor is offline
post #6 of 14 Old 11-23-2010, 06:15 PM
Wouldn't touch it with a 10-ft pole unless it was analog-only, which is easy.
I'm curious about Kaleidescape's BD changer though, but that's a different architecture, and should work like a dream, knowing K-scape.
If I were to do it digitally, I'd go grey-market, use an HDCP stripper and take the HDMI to SDI, then distribute that. It would still be a hodge-podge, but at least it would work reliably. But it would be a very expensive route to go because you'd need professional displays with SDI inputs.
post #7 of 14 Old 05-12-2011, 04:02 PM - Thread Starter
I posted this thread quite a while ago and thought about it again today. I did end up setting up an HDMI distribution system in my house and it has worked great with one hiccup I haven't gotten around to fixing yet. I ended up running two HDMI lines to each of my three main TV's. I then put two 4x4 matrix switchers in the A/v closet, of which I have the following sources hooked up.
-DVR
-Extra cable box
-Xbox
-PS3
-PC
-Video surveillance system
I have one TV capable of 3d and it works great from any source. The only hiccup I have is that for whatever reason it seems like the PS3 video signal is not as strong as all of the others. I have a 75 ft HDMI run to my bedroom on the other side of the house and the PS3 just refuses to display on that TV, but everything else works like a dream. I have a logitech harmony 1100 remote that runs all the switching and works from everywhere in the house and it is just awesome to be able to play xbox or PS3 from anywhere(minus the PS3 in the bedroom). I never did hook up a reciever in the system for surround sound, but for my purposes, I'm very happy with the result.
Long story short, don't be too afraid of HDMI switching these days.
post #8 of 14 Old 05-12-2011, 05:09 PM
GoGo Delicious's Avatar
I am running 4 Kaleidescape Blu-Ray players through my Crestron Fiber based DM System and it works great. You can click on the link below my sig and see my posting on my DM system. Note that I have not updated the thread or pics with the Kaleidescape Blu-Ray setup or the 3D distribution. Maybe I will do that.
GoGo Delicious is offline
post #9 of 14 Old 05-12-2011, 08:17 PM
jautor's Avatar
Liked: 777
But...
Which is why you didn't run into the big issues with HDMI audio distribution.
Glad it worked out for you, just be prepared for some headaches if you try to add 5.1 systems to the mix...
Jeff
jautor is offline
post #10 of 14 Old 05-19-2011, 12:30 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
HDMI is literally the worst possible interface those Hollywood jackinapes could have come up with!
Lousy, flimsy connector, high jitter rate, long-run cable problems, QC issues, about a new cable version a year it seems, makes for horrible A/V distribution, etc. etc.
They better do high quality Fiber Optic or something similar to that the next go around.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #11 of 14 Old 05-19-2011, 12:44 PM
mrted46's Avatar
Quoted: 30 Post(s)
Awesome!
mrted46 is offline
post #12 of 14 Old 05-19-2011, 08:23 PM
DallasKnox's Avatar
HDMI has some definite limitations, but the extremes your taking it too seem harsh.
I think the majority of the problems are a lack of understanding in distribution and bandwidth allocation. With long runs (Especially runs utilizing in-proper cabling), you run the risk of bandwidth bleed.If you plan your runs and use the proper equipment, HDMI can be a blessing. With the ability to buy discrete capable equipment (for EDID and Handshake), at a reasonable price you can setup whole home HD distribution pretty reasonably.
Just the other day CEPRO and SnapAV held a really great webinar addressing distribution of HDMI. I highly recommend it as primer for anyone interested in using HDMI for WholeHome.
http://www.cepro.com/webinars/detail..._make_it_work/
Dallas Knox
DallasKnox is offline
post #13 of 14 Old 05-13-2014, 11:45 AM
mnicic1's Avatar
Hi There,
im in the middle of setting up installing a HDMI distribution around my home, i have installed Cat6A around the house currently, your post about the system you set up at home is the closet thing i can find on the net to what i want to achieve, (on a smaller scale)
I have 3 inputs.
HD Sat
PS3
Blu ray player
HDMI DVR for CCTV
I then have 4 TVs on the system which i would like to view monitor all inputs. how do you go about controlling the PS3 from multiple rooms? also same for Blu ray? you mentioned a Logitech harmony 1100, I'm guessing this will be suitable for Blue ray and satellite?
What did you do for IR Control?
Your help would be gratefully appreciated.
Marc!
mnicic1 is offline
post #14 of 14 Old 05-15-2014, 02:28 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
A few things have changed since 2011 (most systems now utilise HDBaseT and run over a single CAT cable) – though the basics are still much the same (though with less of the hassles we faced in 2011). wink.gif
With a single CAT6 you can now distribute and control multiple HDMI equipped Sources to multiple Zones around your home.
Choose wisely and the HDMI over single CAT system will provided ‘Routed’ IR to allow you to control any Source from Any Zone and where required have two or more of the same sources being controlled from different Zones without IR clashes.
The PS3 is controlled via Bluetooth (if using the game pad) or you can add in an IR controller for BD/DVD playback – are you looking to utilise it for Game or DVD/Blu/ray playback?
You can either use multiple OEM remotes in each Zone or use a programmable remote in each Zone – there is also the option to use Apps plus an iOS or Android Tablet these days.
We have a 4 Input Matrix with up-to 8 plugin Output cards which can be configured as a 4x4 – see http://www.octavainc.com/HDMI_Matrix_HDbaseT_HD4xSTPMX_over%20CAT6.html
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
Reply Home A/V Distribution
