3D over cat5e/component video/coax - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-19-2011, 11:14 PM - Thread Starter
Solomonize's Avatar
I am buying a Panasonic TCP54G25 3D TV with a 3D Blu-ray player. My house is pre-wired with a single cat5e, single coax and component video. I also want to connect FiOS, so I assume I will have a receiver to manage the two inputs. Is there a solution that will allow me to use the existing cables and not have to run HDMI through the walls and 20 feet across the room?
Solomonize is offline
post #2 of 2 Old 01-29-2011, 10:12 AM
victor73's Avatar
There are baluns out there that will transmit HD video over a single cat5e cable. Here's one:
http://snapav.com/snapav/DetailView....-200-1CAT-HDIR
It happens to handle IR and HDMI 1.4a, so that's a really good solution in my opinion.
-Victor
victor73 is offline
Reply Home A/V Distribution
