Anybody get LG AN-WL100 to work on non-LG TVs - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 79 Old 01-23-2013, 03:29 PM
PlayingMantis's Avatar
Anyone that has opened up the transmitter/base notice if there is a way to tap into the HDMI signal before it goes wireless?
I am thinking it would be great if an hdmi output jack could be wired in and disable/remove the wireless function. The receiver unit would not be used. Without the wireless receiver dongle active and paired, I've heard that the input selection buttons stay active on the transmitter box...
Then just run a long hdmi cable, or use in an entertainment center as an hdmi/component/vga switch to add more inputs to the TV
PlayingMantis is offline
post #62 of 79 Old 01-24-2013, 10:44 AM
jeevasv's Avatar
I think it is there in the Wireless Transmitter card. The main board to wireless is not HDMI. It is pure LVDS and I2S for audio. The mainboard is designed for fixing inside LG' TV's. The only thing that it will have in addition is Tuner(ATSC/PAL/SECAM depending on region). But the chipset in the wireless card has many inputs and outputs and I think one of them in HDMI and there are couple of headers which you can try. But we don't know the pinout and the only way is reverse engineering.
PlayingMantis likes this.
jeevasv is offline
post #63 of 79 Old 01-25-2013, 03:19 PM
Wonder if the ATSC tuner could be tapped into...? I have an LG DVD Player/HDTV tuner so it's not something I will probably investigate. As for finding the pinouts, they might be in the patent papers.
Would be interesting if someone with an LG tv could take the mainboard from this and fix their tv lol
post #64 of 79 Old 01-26-2013, 08:08 AM
METDeath's Avatar
Actually, further testing shows that the dongle powers up the Base Station when it powers up. So don't need a power on command, which means one less thing for me to worry about.
METDeath is offline
post #65 of 79 Old 02-21-2013, 12:35 PM
jmm1961's Avatar
I have frustrating situation. Things work fine between my directv box and a VIZIO LCD tv. I followed Ryan's hack of cutting the dongle's 20 pin cable and feeding 18V DC to the red and black.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDIQFjAA&url=https%3A%2F%2Fplus.google.com%2Fu%2F1%2F101948760925084043079%2Fposts%2FbtdqMZqCzEA&ei=RoMmUaCTEMng2gXPo4HADw&usg=AFQjCNE3MvRuOSj_0yA7B7F7u2FMa_ALIw&sig2=1sl6RhmseWXiLCTV5vU48w&bvm=bv.42768644,bs.1,d.b2I
What I really wanted was to feed the signal from the dongle to my Marantz receiver and then to my home theater projector. I got a video but no audio. The receiver display which would indicate the type of audio signal received shows nothing. I have swapped out cables etc with no joy. For testing none exceeded 6 ft. I have read others having problems when feeding to an amplifier. Am I out of luck? Does anyone have any suggestions.
jmm1961 is offline
post #66 of 79 Old 02-25-2013, 04:13 PM
METDeath's Avatar
Next week I can try hooking mine up to my receiver and see if it works correctly.
METDeath is offline
post #67 of 79 Old 02-26-2013, 09:23 AM
jmm1961's Avatar
Thanks, it seems sometimes its very picky. With a denon avr790 receiver I get audio but the wretched green picture that won't reset by power cycling. I wish there was a way to prevent that. The denon shows a 2/0/0 pcm audio signal so I guess either the Marantz receiver doesn't send the right EDID and so no audio is passed or it is confused by the audio part coming from the wireless dongle and cant decode it. I looking to see if one of the boxes that extracts audio strippers from the hdmi signal sheds any light. So far it has a WAF of close to zero eek.gif
jmm1961 is offline
post #68 of 79 Old 02-28-2013, 04:47 PM
carlogan's Avatar
First of all, thank you for this info to everyone, especially Mr. Mckinney. I have two complete units, one on an LG LED and the second on an RCA LCD. Both 1080p. If i turn off the rca and then back on, instantly i get green wash on the picture. i've exchanged the units and the wires so that the only variable is the tv and or some weird voodoo in the air. the rca also does not completely fill the whole screen as there is an inch on the right side without picture. the remedy as stated by previous, is to power cycle the dong or the tx box.
the LG tv works like a champ without any issues with picture. Both tvs are about the same distance from their txs. i have also swaped power supplies. I therefore theorize the rca has an issue with the LG proprietary signal that may change something when it realizes that the tv has been turned off, or that changes something (signal) once it has initialized contact with the rx. Either way, i have to always power cycle if i turn the tv off, even for a second, but once i get good picture, can leave it without issue.
Thanks again to everyone and i welcome any solution.
Long story longer....
I used to have OTA set up when you could get free dish. I live in a remote area and only dish and verizon exist. My daughter is handicapped and stays at home. part of her joy are the kid's channels which she watches on and off during the day. I couldnt use OTA anymore after they fixed the loophole (or did they?) so i got verizon. they charge to use their box and you cannot get a channel without it. so..... you basically rent boxes per tv and cha-ching, hundreds a year just on boxes when your tv is quite capable of dtv channels. to remedy this, i sought out using a splitter and wireless technology to supply both tvs,and a verizon box that costs $15 a month. The good news is that it works thanks to all the info i sponged up in this post. The so-so news is that i have to power cycle one of the tvs everytime i turn it on to get the green-wash out and get a clear picture again. My daughter is happy regardless of which tv shes watching. The bad news: there realy isnt any. $20 wireless devices. paid once for it and it paid itself off in less than two months of use. devices that did semi-similar were over $100. I tinker, i love electronics and have a basic understanding of them. I can solder, and build basic devices and know a little programming. I am very grateful for people like you whom post to help others with little to no reward. thank you once again.
carlogan is offline
post #69 of 79 Old 03-11-2013, 06:59 PM
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
I've only got one problem with this setup. I have a 39" TCL 1080P LED HD TV and no matter what source or input I run through the LG wireless transmitter, I'm left with 1" of unused screen on the right side of the TV no matter what display setting I use on the TV.
Anyone else with similar problems?
jhoffy22 is offline
post #70 of 79 Old 03-11-2013, 09:29 PM
aliinbox's Avatar
It was working great with a Panasonic LED 47" for a month but I had to move it to another place. It stopped working since then. Wireless indicator on the base blinking and never finds the dongle. Dongle was/is powered by an HP laptop power supply 19V 3A. Any idea how it can be fixed?
aliinbox is offline
post #71 of 79 Old 05-04-2013, 01:02 PM
METDeath's Avatar
For those with overscan issues, send it the serial string "kc 01 09\x0D" for a 1:1 scan rate.
METDeath is offline
post #72 of 79 Old 08-01-2013, 12:29 AM
weslebsack's Avatar
Hi Everyone,
I've been trying for the past hour to send commands to my AN-WL100 to no avail. I'm on a Mac, and first I used HyperTerminal though Parallels on Windows 8 using a USB to Serial cable, along with a 3.5mm to serial cable I got on Amazon. No matter which baud rate I used, or which command I sent, I wouldn't get anything in return.
Next I tried using CoolTerm, which is an OS X native serial terminal application. I got the same results. Could someone please verify my settings and make sure I didn't miss something? I really just want to send the kc 01 09\x0D command, to try and fix the overscan issue.
Thank you!
--Wes
weslebsack is offline
post #73 of 79 Old 09-13-2013, 03:28 PM
erihp's Avatar
Originally Posted by weslebsack View Post
Hi Everyone,
Thank you!
--Wes
something tells me the random cable you bought on amazon isnt wired correctly.
erihp is offline
post #74 of 79 Old 11-04-2013, 04:39 PM
bkdg100's Avatar
great to see this thread still going , i would agree that its most likely a bad serial cable , have you tried the cable on another device too proof it ?
bkdg100 is offline
post #75 of 79 Old 05-04-2014, 03:03 AM
rzaandroid's Avatar
Hi I havent yet hooked up my serial but im wondering if theres anyway to change the resolution ? Maybe via the linux shell ? I need to change from 1080p to 1080i there must be an init script that sets the resolution or something ?
rzaandroid is offline
post #76 of 79 Old 01-23-2016, 03:35 PM
Liked: 1
I just got a AN-WL100 and am trying to use an Arduino to send serial commands to change inputs via the service port. Can anyone help me with this? I'm familiar with Arduino, just not hex and the coding commands listed for the inputs. I've been researching ASCII and I don't get it. What does xb (from xb 00 70 = HDMI1) even mean? I see 00 and 70 as hex but no xb. I imagine that I would "Serial.write()" whatever xb 00 70 is to get HDMI1 selected but I need help with the coding
alphacheese is offline
post #77 of 79 Old 04-14-2016, 08:32 AM
Liked: 1
Ok! I got it all figured out! Here is my sketch I wrote to change the inputs of an LG AN-WL100W wireless transmitter. Please note for my unit this is the correct pinout:
connect tip of 3.5mm to pin 2 of db9 (not 3 as stated by previous author)
connect ring of 3.5mm to pin 3 of db9 (not 2 as stated by previous author)
connect sleeve of 3.5mm to pin 5 of db9" (ground)
In lieu of db9 connections you might be using a mini MAX3232 RS232 to TTL converter. Connect the Arduino's software serial RX pin to the TX pin of the MAX3232 and Arduino's software serial TX pin to the RX pin of the MAX3232. It's hard to tell which is which on the mini as they are labeled with arrows not text. Also, the correct baud rate for my transmitter was 9600.
I am using a 4x4 matrix keypad for buttons and only wiring buttons 1-9 to save space on my Arduino for other pins. If you need more pins there are tutorials to setup the keypad using only one analog input I plan to add an LCD at some point to confirm button press and input change but for now your receiver unit will display what input has been selected via the HDMI display its plugged in to. The front of the transmitter unit will not indicate what input has selected and the soft buttons do not work, hence the purpose for this sketch. Maybe the next step will be to open the sucker up and wire in the soft buttons and LEDs to the Arduino! Oooh that sounds exciting
Arduino sketch:
#include <Keypad.h>
#include <SoftwareSerial.h>
SoftwareSerial TV_Serial(10, 11); // Arduino RX, Arduino TX
const byte ROWS = 3; //four rows
const byte COLS = 3; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
byte rowPins[ROWS] = {9, 8, 7}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
Serial.begin(9600);
TV_Serial.begin(9600);
void loop(){
char customKey = customKeypad.getKey();
if (customKey == '1'){
TV_Serial.println("xb 00 20\r");
Serial.println("AV1");
if (customKey == '2'){
TV_Serial.println("xb 00 21\r");
Serial.println("AV2");
if (customKey == '3'){
TV_Serial.println("xb 00 40\r");
Serial.println("Component1");
if (customKey == '4'){
TV_Serial.println("xb 00 41\r");
Serial.println("Component2");
if (customKey == '5'){
TV_Serial.println("xb 00 60\r");
Serial.println("RGB/VGA");
if (customKey == '6'){
TV_Serial.println("xb 00 70\r");
Serial.println("HDMI1");
if (customKey == '7'){
TV_Serial.println("xb 00 71\r");
Serial.println("HDMI2");
if (customKey == '8'){
TV_Serial.println("xb 00 72\r");
Serial.println("HDMI3");
if (customKey == '9'){
TV_Serial.println("xb 00 73\r");
Serial.println("HDMI4");
JoshFink likes this.
post #78 of 79 Old 09-18-2016, 01:50 PM
Liked: 0
LG AN-WL100 controlled by openHab
I'm glad to see I'm not the only that still thinks this device is worth a little effort to use. It's unfortunate that LG abandoned it so quickly, but it's been great to get these for almost nothing. I've been using one on my LG 42LV5500 every since they started dumping them and bought a couple of more as spares/toys. I did the dongle hack about 3 years ago on my spares, but never found what I thought was a suitable method of control for non compatible tvs. Recently I started using openHab (with another mfg abandoned product, TCP connected light bulbs). I then decided it might be a good way to interface to the LG AN-WL100.
Since I was running openHab on an RPI2, I just plugged in USB-serial converter connected to a db9 to trs cable and plugged it into the service port. Instead of writing one python script to handle all commands, I wrote individual python scripts to send each unique command. In my openHab sitemap, I implemented a Selection device with an entry for each input selection and the off command. I then created a rule for the selection of each entry, that when triggered, executes the python script for that command.
Once the openHab interface was implemented, it became available for use via openHab's browser interface, android and ios apps on my local network. With registration to my.openhab.org, it's also available remotely and can be triggered by IFTTT recipes if desired. Not sure what the remote access adds for this device, but the IFTTT recipes might be fun to play with.
The real value is having cross platform UIs for a remote. I have the openHab app installed on my Nexus 5 phone and my Nexus 7 tablet. I've got 3 or 4 more compatible android devices around the house I can use in addition. Add that to the ability to access the web UI from a browser on any of my computers and I'll never be searching a misplaced remote.
openHab is not a simple thing to get up and running for the non-technically inclined, but the return on investment is pretty high. Once you have it running properly and have an understanding of how it works, it gives you the ability to integrate many protocols into a single interface. I'm probably going to purchase an Amazon Dot(v2) when it's released in Oct 2016 and integrate it for voice control of my openHab devices at home. It's going to sell for $49.99, with the same capabilities of the much higher priced Echo. A bargain compared to the Echo if don't intend to use the audio playback capabilities of the Echo. If it works out well, there may be one in every room.
gbealmer is offline
post #79 of 79 Old Today, 11:13 AM
ben_r_'s Avatar
There are still some of us out here looking into these. I just found the one I bought back at the end of 2012 in my garage, still brand new and unopened. Glad to see so much has been done to hack these units. Look forward to messing with mine soon.
ben_r_ is online now
Reply Home A/V Distribution
