Component Balun Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-21-2011, 11:00 AM - Thread Starter
mtorchio's Avatar
i am using the calrad 40-7110 balun kit to extend component video from a dvd player to an new LG 42" lcd display. The run is about 75 feet. after the initial connections were made i was able to receive a signal and had video on the display. The next day the display was showing an "invalid format" icon and i have not been able to get the image back. i tried using different baluns that work on another display and i get same result. i then brought the dvd player to the room, used the baluns with a pre-made cable and it worked, i received the video. i was thinking it was a cable issue and re-terminated the ends several times with no change. what boggles me is that it worked one day and then not the next. Any Ideas?
mtorchio is offline
post #2 of 4 Old 02-21-2011, 02:27 PM
ericspencer's Avatar
Could be a cable skew issue.. are you using cat5e or cat6.. cat6 tends to have more issues if the baluns do not have built-in compensation for cable skew. Not sure on these units as I have never used them, we use intelix and they have built in compensation.
ericspencer is offline
post #3 of 4 Old 02-21-2011, 02:48 PM - Thread Starter
mtorchio's Avatar
thanks for the response. i am using cat5e cabling. i will look into whether these baluns have the built in compensation. is there a part to use to fix the issue if skew is the issue? or would you recommend purchasing different baluns?
mtorchio is offline
post #4 of 4 Old 02-22-2011, 09:02 AM - Thread Starter
mtorchio's Avatar
the baluns have an adjustment screw for peak, which i was believe is for skew.
mtorchio is offline
Reply Home A/V Distribution
