Seeking HDMI + Toslink (4X2) switcher - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-28-2011, 08:08 AM - Thread Starter
gadget-zilla's Avatar
Quoted: 21 Post(s)
Seeking a 4X2 (four input - two output) switcher that is for HDMI connectors. The switcher must also have TOSLINK optical output.
I have an older receiver that does not have HDMI connectors hence the need to use TOSLINK optical.
My four inputs will be:
-PS3
-media streamer
-Sony DVR
-HDTV Tuner
outputs will be:
-an LCD TV
-a projector.
I do not need to mirror the outputs - just want to be able to select either/or from LCD TV or the projector.
If the switcher has more inputs, example: 6X2, I'm good with that too
In reading various posts, a lot of folks are using one from Monoprice - unfortunately, I do not have COAX optical outputs on some devices hence the requirement for a TOSLINK optical based switcher.
any reasonable suggestions ?
gadget-zilla is offline
post #2 of 7 Old 02-28-2011, 08:43 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
You can get optical->coax digital converters (also from Monoprice) for <$20...
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 7 Old 02-28-2011, 12:22 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
This one accepts 4 HDMI inputs and has the capability to convert and output audio via toslink (or digital coaxial).
If you need two optical outputs just get a coax to optical converter as jautor has suggested and you'll have two optical outputs.
Vin
Vin is offline
post #4 of 7 Old 02-28-2011, 01:17 PM - Thread Starter
Quoted: 21 Post(s)
Thanks for the feedback !!
Vin - The one above you recommended, it has only one output (1X4), I was looking for two outputs
Just wondering, any thoughts on this device ?
http://www.hdtvsupply.com/4x2-hdmi-m...tal-audio.html
It is is more money, in comparing to monoprice
post #5 of 7 Old 03-01-2011, 11:39 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I guess I misunderstood you, I didn't realilze you needed 2 HDMI outputs in addition to optical out...if that's the case, this one looks very similar to the one you're considering for a lot less money.
Vin
Vin is offline
post #6 of 7 Old 03-04-2011, 07:21 AM - Thread Starter
Quoted: 21 Post(s)
Vin - Thanks for the link. I took a closer look, and it is the same exact unit that monoprice sells. I spoke with monoprice, unfortunately, the coax digital only outputs on 'ouput A'. I needed a device that outputs on A and B
The past two days, I researched the Octava (5input 2 output) and the gefen (4 input two output) units.
It was a very difficult choice as there are not any recent posts for these units so I had to base my decision on old information.
In the end, I want a switcher that will just work. Gefen 'appears' to do just that (based on the reading I did on the device) so I opted to spend more and ordered the gefen 4 input 2 output + digital output.
Once I get the unit, I will post details of my experience with the device, along with some screenshots.
post #7 of 7 Old 01-03-2013, 10:11 AM
eaadams's Avatar
Quoted: 52 Post(s)
How did this work for you? Did whatever you get still send audio over HDMI while also outputing audio on the toslink/optical? That is what I am looking for: 2in / 2out (same time) and 1 toslink / optical out.
eaadams is offline
Reply Home A/V Distribution
